I saw many post on the forum, but did not find my needs :
What is the linker region-related symbol for LR_IROM1 COMPRESSED SIZE ?
Or in case it does not exist :
How can I inject a constant value into my object file after compilation ? (As I could read my former symbol in the MAP file ...)
Thanks for help.
Regards Hervé.
As this variable is not available in the linker symbols, I wonder if it is possible to get it during runtime.
After performing variable decompression, the register R0 hold the end of the initialisation table. Up to the __scatterload_zeroinit the register R0 is not used
SO I put that code into the Lpc23xx_keil.s
The problem is that I can't go back to the original initialisation function :
How can I call the original scatterload_zeroinit entry point after storing my data ?
EXPORT __scatterload_zeroinit IMPORT CodeZoneEnd __scatterload_zeroinit LDR R1, = CodeZoneEnd ; give access to the backup function STR R0, [R1] BX LR
