Who here have experience of running software written for 80C52 on LPC1778? Is it likely to work right away or will it crash? I have an existing design with existing software that I'm thinking of upgrading.
It will crash big time! Bradford
.... The only part that would be transferrable (maybe unchanged, maybe not) would be the non I/O part.
however by the "looking to the left while coding at the right" it is no enormous deal to port a job, days, not months.
Foks; Sorry to hijack this post but I'm having problems. A number of words are double underlined in blue. These words are links to pop up ads. Do I have a virus? Are any of you seeing this problem? I just ran my virus scanner this AM with no virsus reported.
Bradford
Had to set my pop up blocker to highest setting. Will try find out what URL is high jacking my inet.
You mean words in this thread?
No - never seen that!
"Is it likely to work right away"
It is unlikely in the extreme that it will even build straight away!
However, If it is carefully designed for portability; ie, target dependencies (including toolset dependencies) are minimised and carefully isolated into easily identified areas, then the job of porting should be straightforward.
But, if that were the case, would you have had to ask the question...?
