Hi, I am new here I have been trying to use examples from ST site, I have downloaded examples and firmware for board I got STM32 DISCOVERY. When I am openning the examples from ST it is not compiling at all! I got these messages:
STM32_Init.c: Error: C3065E: type of input file 'Files' unknown STM32_Init.c: Error: C3065E: type of input file '(x86)\STMicroelectronics\STM32L_Discovery_Firmware_Pack_V1.0.2\Libraries\STM32L1xx_StdPeriph_Driver\inc' unknown Target not created
Why is this? Any one has an idea?
Thanks, Roee
That sounds like you have spaces in your pathname...
You could either spend time trying to discover how to get the tools to cope with spaces in pathnames or, I would recommend, don't use spaces in your pathnames!
Thanks, When I downloaded from ST all the files I got it to compile ok. But I have a new question: How can I add in project configuration wizard all the options to configure things via windows? Is there a C file that gives me the option to add things in buttons and writing less C code? Thanks, Roee
get it from the horses mouth get ST files from ST, not Keil, not www.bunchofdatafiles.com get datasheets from the manufacturer not Keil, not www.datasheetsgalore.com get Keil generated files from Keil
relying on a second party to be up to date is foolish.
In that case, you should start a new thread.
You can always link to this thread, if you think it helps.
But I don't understand your question, so you also need to expand your description.
Andrew; I believe the OP is asking about the Templates ability within uVision. I do not have Keil on this computer so I cannot give him any references. Could you point out the templates ability to see if this is his question? Thanks, Bradford
