Hello all! I'm trying to write simple SNTP client with BSD sockets. I wrote such code:
#include "LPC23xx.h" #include "uart.h" #include "RTL.h" #include "main.h" #include <Net_Config.h> //-------- <<< Use Configuration Wizard in Context Menu >>> ----------------- // <h>Time server IP // ==================== // // <o>IP1: Address byte 1 <0-255> // Default: 192 #define IP1 192 // <o>IP2: Address byte 2 <0-255> // Default: 168 #define IP2 168 // <o>IP3: Address byte 3 <0-255> // Default: 0 #define IP3 0 // <o>IP4: Address byte 4 <0-255> // Default: 100 #define IP4 13 // </h> //------------- <<< end of configuration section >>> ----------------------- OS_TID poolID, timerID, SNTPID; char rx_buf[150]; U64 tcp_stack[800/8]; U64 SNTP_stack[800/8]; #define MCLK 48000000 /* Master Clock 48 MHz */ #define TCLK 10 /* Timer Clock rate 10/s */ #define TCNT (MCLK/TCLK/4) /* Timer Counts */ BOOL tick; U32 dhcp_tout; BOOL LCDupdate; extern LOCALM localm[]; /* Local Machine Settings */ #define MY_IP localm[NETIF_ETH].IpAdr #define DHCP_TOUT 50 /* DHCP timeout 5 seconds */ void tcp_task (void) { /* Main Thread of the TcpNet. This task should have */ /* the lowest priority because it is always READY. */ UART2_init(115200); init_TcpNet(); timerID=os_tsk_create (timer_task, 0x20); //poolID=os_tsk_create_user (tcp_task, 0, &tcp_stack, sizeof(tcp_stack)); //os_dly_wait(1000); SNTPID=os_tsk_create_user (SNTP_task, 0x02, &SNTP_stack, sizeof(SNTP_stack)); while (1) { main_TcpNet(); os_tsk_pass(); } } /*--------------------------- timer_poll ------------------------------------*/ void timer_task (void) { os_itv_set (10); while (1) { /* Timer tick every 100 ms */ timer_tick (); tick = __TRUE; os_itv_wait (); } } void SNTP_task (void) { //static int sock; int sock; int res; int addrlen; SOCKADDR_IN time_addr; char tx_buf[50]; tx_buf[0]=0x23; //SNTPV4 client send_string2("SNTP task started\r\n"); addrlen = sizeof (time_addr); while(1) { sock = socket (AF_INET, SOCK_DGRAM, IPPROTO_UDP); if (sock>0) { time_addr.sin_port = htons(5001); time_addr.sin_family = PF_INET; time_addr.sin_addr.s_b1 = IP1; time_addr.sin_addr.s_b2 = IP2; time_addr.sin_addr.s_b3 = IP3; time_addr.sin_addr.s_b4 = IP4; connect (sock, (SOCKADDR *)&time_addr, sizeof (time_addr)); while(1) { res = sendto (sock, (char *)&tx_buf, 48, 0, (SOCKADDR*)&time_addr, addrlen); if (res <0) { break; } send_string2("Get-time request sent\r\n"); res = recv (sock, rx_buf, 48, 0); if (res <0) { switch (res) { case SCK_EINVALID: send_string2("socket invalid\r\n"); break; case SCK_ECLOSED: { send_string2("remote host closed\r\n"); break; } case SCK_EWOULDBLOCK: { send_string2("function would be locked\r\n"); break; } case SCK_ETIMEOUT: send_string2("timeout\r\n"); break; case SCK_ELOCKED: { send_string2("function blocked by RTX\r\n"); break; } } break; } os_dly_wait(300); } closesocket (sock); os_dly_wait(300); } else { send_string2("Create socket error!\r\n"); while(1); } } } int main (void) { os_sys_init_user (tcp_task, 0, &tcp_stack, sizeof(tcp_stack)); }
where SNTP_task is SNTP client. Sending request by send() or sendto() functions is good, but functions recv() and recvfrom returns SCK_EINVALID error. When I delete send() function, recv() return error too. I'm tried Keil 4.5 and Keil 4.53. TCPNet options: two UDP native socket, one TCP native socket, one BSD socket, Receive timeout 20 s. Thank you. Andrei
