USB CDC class problem with Windows usbser.sys
Hoping to get some expert advice here,
Have an embedded USB application running on a Cortex M4. Application uses full-speed USB and is based on a Freescale-provided CDC USB sample project. My bulk "IN" endpoint is defined for 64 bytes. Embedded application is communicating with an XP-SP3 2.5GHZ Core2 Duo laptop using the usbser.sys device driver and a COM program. I'm also running a software USB analyzer (USBlyzer). I have come up to speed on USB about as much as I humanly can in a few week's time, including reading Jan Axelson's "USB Complete", so I'd like to think I know mostly what is going on.
Every millisecond, my embedded application needs to send to the host PC roughly 500 bytes in a single "IN" transaction. According to everything I read, I should be able to do this by sending a burst of eight 64 byte packets followed by a ZLP to terminate the transaction. So here's what's happening; the terminal application polls my device with an IN request using a 4096 byte buffer. This generates a "token received" interrupt on my embedded device which I _immediately_ service by sending a burst of 8 consecutive packets followed by a ZLP. (I also made sure to wait for clear of the "OWN" bit during this burst). Half these packets appear to be lost on the other end. The only way I can seem to get reliable transfer is if I send single packet per transaction and wait for the host PC to send the next "IN" request before starting a new transaction. This winds up killing my performance.
Am I simply asking too much of the usbser.sys driver or am I missing something simple here?
