ARM: PWM Output problems on MCBSTM32F200
Greetings,
I am currently toying around with the KEIL MCBSTM32F200 Evaluation Board
(the STM32F207VG uC) and have run into some problems with the PWM output.
I want a simple PWM-signal on TIM1, Channel1 (PA8 for STM32F205&207) using
the standard peripheral library for STM32Fxx.
The code below is a mix from the different examples from the standard
peripheral library examples for PWM, and I'm sure something critical is
missing.
After initializing, all TIM1 registers looks "ok" (as far as I can tell, the
timer is a bit too advanced for me...) and the TIM1_CNT register is counting
up and resetting.
When connecting the oscilloscope to PA8, all I get is a steady 3.3V signal,
no PWM.
What am I missing here? It's quite frustrating since all other peripherals
I'm using are working fine. Thanks in advance.
(code also at Pastebin: http://pastebin.com/yUmZbXUL)
#include "stm32f2xx.h"
#include "stm32f2xx_gpio.h"
#include "stm32f2xx_rcc.h"
#include "stm32f2xx_tim.h"
#include "system_stm32f2xx.h"
void main(void) {
        TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure;
        TIM_OCInitTypeDef               TIM_OCInitStructure;
        GPIO_InitTypeDef                GPIO_InitStructure;
        uint16_t                                period;
        uint16_t                                pulse;
        /* Initialize clock - defined in system_stm32f2xx.h */
        SystemInit();
        /* Compute the value for the ARR register to have a period of 20 KHz */
        period = (SystemCoreClock / 20000 ) - 1;
        /* Compute the CCR1 value to generate a PWN signal with 50% duty cycle */
        pulse = (uint16_t) (((uint32_t) 5 * (period - 1)) / 10);
        /* GPIOA clock enable */
        RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOA, ENABLE);
        /* Initialize PA8, Alternative Function, 100Mhz, Output, Push-pull */
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8;
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;
        GPIO_InitStructure.GPIO_Speed = GPIO_Speed_100MHz;
        GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
        GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP ;
        GPIO_Init(GPIOA, &GPIO_InitStructure);
        GPIO_PinAFConfig(GPIOA, GPIO_PinSource8, GPIO_AF_TIM1);
        /* TIM1 clock enable */
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_TIM1 , ENABLE);
        /* Timer Base configuration */
        TIM_TimeBaseStructInit(&TIM_TimeBaseStructure);
        TIM_TimeBaseStructure.TIM_Prescaler = 0;
        TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
        TIM_TimeBaseStructure.TIM_Period = period;
        TIM_TimeBaseStructure.TIM_ClockDivision = 0;
        TIM_TimeBaseStructure.TIM_RepetitionCounter = 0;
        TIM_TimeBaseInit(TIM1, &TIM_TimeBaseStructure);
        /* Channel 1 output configuration */
        TIM_OCStructInit(&TIM_OCInitStructure);
        TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM2;
        TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;
        TIM_OCInitStructure.TIM_Pulse = pulse;
        TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_Low;
        TIM_OCInitStructure.TIM_OCIdleState = TIM_OCIdleState_Set;
        TIM_OC1Init(TIM1, &TIM_OCInitStructure);
        /* TIM1 counter enable */
        TIM_Cmd(TIM1, ENABLE);
        /* TIM1 Main Output Enable */
        TIM_CtrlPWMOutputs(TIM1, ENABLE);
        /* forever... */
        while (1) {
                __asm("nop");
