make a timer to ..,.well time
I am new so hang with me as i drivel on,
i just want to set up a timer on the MCB900 using an lpc935,
all i want is to count to a second or 2 so i can use this to measure inputs a set time apart.
And before someone replies 'its simple' bla bla bla, keep in mind i am very new to this baby steps first pleeeeeeeeese roy
  • oh well baby steps, if you hit your toe, don't cry
    1) the LPC935 is not 'none' it is a '51, enter type correctly
    2) the timer can not do times as long as seconds, so what you do in paseudocode
    either
    seconds_times_100 = whatever you need
    set_timer_to_run_for_10_milliseconds();
    loop till timer flag
    loop2:
    restart timer
    decrement seconds_times_100
    if seconds_times_100 expired you are done
    else loop2:
    or
    when seconds_times_100 is zero, you have waited long enough
    timer_ISR
    restart timer
    if seconds_times_100 not zero
  • all i want is to count to a second or 2 so i can use this to measure inputs a set time apart.
    The actual execution will depend on your (more specific) requirements.
    In general, you want to run an isr that counts time at a pre-set interval. And in the isr, you count the number of times the isr has been executed as a way to gauge if a long period of time has passed. You can then set a flag and process that flag accordingly, in the isr or in the main.
