I am new so hang with me as i drivel on,
i just want to set up a timer on the MCB900 using an lpc935, all i want is to count to a second or 2 so i can use this to measure inputs a set time apart. And before someone replies 'its simple' bla bla bla, keep in mind i am very new to this baby steps first pleeeeeeeeese roy
oh well baby steps, if you hit your toe, don't cry
1) the LPC935 is not 'none' it is a '51, enter type correctly
2) the timer can not do times as long as seconds, so what you do in paseudocode
either seconds_times_100 = whatever you need set_timer_to_run_for_10_milliseconds(); loop till timer flag loop2: restart timer decrement seconds_times_100 if seconds_times_100 expired you are done else loop2:
or seconds_times_100 = whatever you need set_timer_to_run_for_10_milliseconds(); when seconds_times_100 is zero, you have waited long enough
timer_ISR restart timer if seconds_times_100 not zero decrement seconds_times_100
