Need help Minimon + C167 + 29F400 (Read Ok/Write impossible)
Need help for Minimon + C167 + 29F400 (Read Ok/Write impossible)
Hello all!
I try to write in 29F400 but I need help with Minimon.
I did a lot of tests for hours and hours.
I read lots of informations on the net.
Infineon C167CS User Manual is very useful but I need help.
I can read 29F400 with success OK!
But impossible to Write or Erase...
I had set driver A29F400b.hex
I think the problem come from the registers settings Buscon and Addrsel because maybe I don't understand all very well.
What should be the settings in the [Register] and [Memory] section in file Default.ini ?
What should be 29f400 start address with my config?
Here is my config:
C167CS-LM (No internal Rom)
8mhz x 3 = 24mhz
Connected in Boot-Mode with asc0 port (Usart, NOT K-line)
4MB Flash (AM29F400BB-55)
Word Mode (16 Bit ; Pin "BYTE" to +5V)
16 Bit demultiplexed Bus
OE to C167 Pin CS0 (P6.0)
WE to C167 Pin CS1 (P6.1)
CE to Ground
*Reset: BUSCON0=0680
*Reset: SYSCON=0400
*Reset Configuration: External Bus enabled
*Reset Configuration: 16 Bit demultiplexed Bus
*Reset Configuration: WR# and BHE# retain their normal function (P0H.0=0)
*Reset Configuration: On chip watchdog timer is disabled (RD#=0)
*Reset Configuration: Lengthened ALE signal
RP0H=00C7 (5 "chip select" activated) ...But I think only 3 CS signals are used, CS0,CS1, and CS3 connected on 74HCT574D Clock Input (Pin 11)
Address Pinout
29F400 / C167
A0 / A1
A1 / A2
A2 / A3
A3 / A4
A4 / A5
A5 / A6
A6 / A7
A7 / A8
A8 / A9
A9 / A10
A10 / A11
A11 / A12
A12 / A13
A13 / A14
A14 / A15
A15 / A16
A16 / A17
A17 / A18
Data Pinout
29F400 / C167
DQ0 / AD15
DQ1 / AD13
DQ2 / AD11
DQ3 / AD9
DQ4 / AD0
DQ5 / AD2
DQ6 / AD4
DQ7 / AD6
DQ8 / AD14
DQ9 / AD12
DQ10 / AD10
DQ11 / AD8
DQ12 / AD1
DQ13 / AD3
DQ14 / AD5
DQ15 / AD7
Thank you for your big help!
Chris
