MDK-ARM Plug-in for Eclipse: UVSCWrapper.dll failed to load
I have installed the uVision plugin for Eclipse, but when I want to flash download configuration I get the following error:
UVSCWrapper.dll failed to load.
java.lang.UnsatisfiedLinkError: com.keil.uv4.uvsc.wrapper.UVSCWrapperDLLJNI.swig_module_init()V
Eclipse version:
Eclipse IDE for C/C++ Developers
Version: Indigo Service Release 1
Build id: 20110916-0149
Keil uVision version:
IDE-Version:
µVision V4.23.00.0
Copyright (C) 2011 ARM Ltd and ARM Germany GmbH. All rights reserved.
License Information:
Eric Bosch
Philips Lighting
LIC=ATTJR-HL287-WJJV7-CMFWK-14DJQ-ABNCF
Tool Version Numbers:
Toolchain: MDK-ARM Standard: 15 user Version: 4.23
Toolchain Path: C:\Keil\4.23\ARM\BIN40
C Compiler: Armcc.Exe V4.1.0.894
Assembler: Armasm.Exe V4.1.0.894
Linker/Locator: ArmLink.Exe V4.1.0.894
Librarian: ArmAr.Exe V4.1.0.894
Hex Converter: FromElf.Exe V4.1.0.894
CPU DLL: SARMCM3.DLL V4.23
Dialog DLL: DARMSTM.DLL V1.63.0.0
Target DLL: UL2CM3.DLL V1.95
Dialog DLL: TARMSTM.DLL V1.60
