LPC9107 debugging
Has anyone tried debugging a LPC9107 using an EPM900. It is listed as being supported, but the pin-out doesn't match the EPM900. OK, so I can make up a cable. More importantly, how do you set Port pin P1.2 as a push-pull O/P? I know it's not allowed on the 920 and 930 series due to its alternative function as part of the I2C bus, but, according to the 9107 documentation, there is no limitation on this pin - only P1.5. Also the 9107 has no I2C bus. Whatever I do with the port config registers, P1M1 bit 2 remains permanently set. Any ideas (other than sticking a pull-up resistor onto the pin)?
