I am working with Kiel but i am getting more errors as uncalled segment please can anybody tell me the way of removing those errors.... other then removing/commenting that particular segment
"i am getting more errors as uncalled segment"
More than what?
Are you sure they are actually errors - not just warnings?
"other then removing/commenting that particular segment"
No - there is no other way!
If they are not called, then there is obviously no way to avoid the message which tells you that they are not called!
Why do you have uncalled segments in your code?
Do you understand why this could be a Very Bad Thing and, thus, why the tools warn you about it?
those are warnings.
the only way to eliminate them would be to delete the uncalled code from your source file.
you can turn off all warnings to suppress such messages but it doesn't nothing to address them.
the only way to eliminate them would be to delete the uncalled code from your source file. not the only way, surruound them with #ifdef IN_USE
Or you could take the other approach and put in code that accesses the segments.
