Hi everbody,i guess, i have some problem about 8051 control Gsm modem with AT command i have Enfora Gsm modem(it have rs232 socket input) and 8051 board(it include AT89c51rc2 and max232) 1.i communicated 8051 to pc (19200,8bit no party,1 stop,handshake none ) 2.i communicated gsm modem to pc (same values ,Firts i setup gsm modem(AT+IFC ,AT+ICF, AT&D0(dtr unable) command) ) i thinks ,hardware and synchronization is well (but just for PC) but i could not communicate 8051 to Gsm modem, code is down (just send AT and response)
void SendAT(void) { putchar('A'); putchar('T'); putchar(0x0d); } void main() { //****************************************** IE=0x90; SCON=0x50; PCON=0x80; // 2 much more baudrate (19200) TMOD=0x20; TL1=0xFD; TH1=0xFD; // yaklasik 9600 bps(11.0592Mhz) TR1=1; // Z/S 1'i çalistir. TI=1; // gönderilmeye hazir RI=0; //*************************************************** longwait(); //wait funk. nearly 2 sn SendAT(); while(RI ==0) { //show display wait } //when i connect 8051 with gsm modem //program always wait here line but //connect 8051 to pc and pc send serial something //program continue working //i mean ,not coming response gms modem or //nothing arrive gms modem if(RI==1 ){ //show display ok } else{//show display error } }
how can i do , thanks for all now(please write quick, i really need help)
Are you sure that you have your cable correctly wired & correctly connected?
http://www.keil.com/forum/10745/
http://www.keil.com/forum/9483/
1.i communicated 8051 to pc (19200,8bit no party,1 stop,handshake none ) if this cable is "a to b" 2.i communicated gsm modem to pc (same values , and if this cable is "a to b" but i could not communicate 8051 to Gsm modem then this cable must be "a to a"
That is necessary - but may not be sufficient.
See the links already given...
