Memory size increase with uVission4
We worked previously with the uVision3 with following components and optimization level 0:
uVision3 V3.70
Toolchain: MDK-ARM Standard 3.30
C Compiler: V3.1.0.942
SARMCM3.DLL: V3.30
DARMSTM.DLL: V1.37
Compiler Control string:
-c --device DARMSTM -g -O0 --apcs=interwork
The BUILD OUTPUT is:
Program Size: Code=109260 RO-data=12552 RW-data=820 ZI-data=16840
With the uVision4 we got memory problems with this optimization level!!!
vVision V4.20.03.0
Toolchain: 4.20
C Compiler: V4.1.0.644
SARMCM3.DLL V4.20
DARMSTM.DLL V1.62
-c --cpu Cortex-M3 -g -O0 --apcs=interwork
And the BUILD OUTPUT is:
.\Debug\objects\rectifierDebug.axf: Error: L6220E: Load region LR_MyProject size (127148 bytes) exceeds limit (122880 bytes). Region contains 148 bytes of padding and 0 bytes of veneers (total 148 bytes of linker generated content).
For another project (much smaller memory size, app. 73k) which was possible to build with uVision4, I found that the memory size was app. 3k higher as I build it with uVision3.
I saw that the compiler control string is different, but how can I cahnge this. What is the reason for this much more memory??? I think it's not normal that the memory size increase with a new compiler version!
Thank you for support.
Best regards, Carsten
