<H> SD CARD WRITE AND READ </H>
<BODY> I was interfaced 512MB sd card with lpc2148, in my coding data is written only in 0th block(sector) only, how to write the data in another block(1st,2nd....blocks(sectors)).</BODY>
www.lmgtfy.com
Why do you think you should add HTML tags to your question?
Did it seem to work?
Why did you continue past the preview stage with the HTML tags still there then?
please send u r code
