Currently im developing a project which takes advantage of the In Application Programming feature on the ARM7 MCU. These individual projects are a Bootloader (IAP enabled) and a Main Application.
Ive found that both Apps utilise the same drivers etc but have not seen a way in which Bootloader and Main Application firmware can reference the same drivers. In doing so I can save vast amounts of code space etc. Im not sure where to start, ive seen older examples from uvision2, 8051 but nothing relevant for this MCU/Keil's Uvision4 IDE. Any ideas / keywords will be appreciated as currently ive not seen anything useful to use with the ARM7 MCU yet.
Thanking you in advance
DSP
