I2C Simulation
Hi, I’m designing a micro system on an ADuC842 with I2C communications between ICs. I using Keil to design and debug my code but I’m having trouble interpreting the display from the I2C interface window. I wrote code for a slave device and used Keil I2C interface to communicate with it successfully but I can’t tell if my master code is working or not because the interface window confuses me.
I would be very grateful if someone could help me out and explain how to verify that my master code is working, as in what does the window do when you successfully communicate with it?
Thanks,
Donagh
  • there are 1000's of examples of "special hardware interfaces" for the 1000s of '51 derivatives.
    to expect Keil to simulate them all is unreasonable.
    Keil produces and sell a compiler and provide a simulator as a service.
    use JTAG debug or whatever in that line your chip has.
    if you chip does not have JTAG or similar, switch to a SILabs chip (temporarily during development)
