Is there a way using C51/Cx51 to easily switch based on the memory type of a generic pointer? So far, the best thing I have is:
void my_func(void * ptr) { switch(*(uint8_t *)&ptr) { case 0x00: // do data/idata-specific stuff case 0x01: // do xdata-specific stuff case 0xff: // do code-specific stuff default: // do error-handling } }
what on earth are you doing??? the switch variable must have the case operands defined. there can be no variance.
No, the switch operand is the pointer; or rather, just the first byte of the generic pointer representing the memory type.
It doesn't have to be a switch statement, I'm just wondering if there is a built-in way in Keil to determine the memory type of a generic pointer at run time -- if someone passes me an XDATA pointer, do this; if they pass me a CODE pointer, do that.
printf() can do that with the "%p" format specification:
http://www.keil.com/support/man/docs/c51/c51_printf.htm
But that's probably not what you are after. Since the format of a generic pointer is specified in the manual, I think it's safe to do it the way your did.
OK cool, thanks =)
