#include<softuart.h> #include<stdio.h> #include<reg51.h>
void uart_init(); sbit sw=P1^7;
unsigned char rx(); code unsigned char rd[] = "AT+CMGR=1"; code unsigned char ne[] = "AT+CNMI=2,2,0,0,0"; unsigned int r=0,m=0,s1=0,n1=0,f1=0,m2=0; unsigned char gs,mes_dat[]=0,mess[]=0; extern void lcd_init(); void lcd_cmd(unsigned char); void lcd_data(unsigned char); //void wait();
void gsm_delay(unsigned int); unsigned char txt[]="AT+CMGF=1"; unsigned char no[] ="AT+CMGS=\"9940151239\""; unsigned char del[]="AT+CMGDA=\"DEL ALL\"";
unsigned char sen[]="SENSOR";
void send_no(); void new_mess(); void gsm_read();
void delete(); void gsm_read(); void mode(); unsigned char rx(); unsigned char w, re,rx_data; void tx(unsigned char);
void serial(void) interrupt 4 {
if(TI==1) { TI=0; SBUF = '\0'; //ES=0; } else if(RI==1) { rx_data = SBUF;
if(rx_data=='+') { do { mess[m2] = rx_data;
m2++; RI=0; }while(rx_data=='T'); }
RI = 0; } }
void main() { uart_init(); lcd_init(); mode(); new_mess();
// delete();
while(1) { IE = 0x90; m = 0; r = 0; s1 = 0; m2 = 0;
re = rx_data;
if(re=='+') { RI = 0;
if(SBUF=='C') { lcd_data('1'); RI = 0; if(re=='M') { RI=0; lcd_data('2'); if(re=='T') { RI=0; do { gs = re; RI = 0; }while(gs!=0x0a);
m=-1; do { m = m+1;
mes_dat[m] = re; RI = 0;
}while(mes_dat[m]!=0x0d); mes_dat[m] = '\0'; m=0; lcd_cmd(0x01); lcd_cmd(0x80); while(mes_dat[m]!='\0') { lcd_data(mes_dat[m]); m++; } } } } } while(sw==1); m2=0; while(mess[m2]!='T') { //lcd_data(mess[m2]); tx(mess[m2]); m2++; }
send_no();
while(sen[s1]!='\0') { putc(sen[s1]); s1++; } putc(0x1a);
lcd_data('L');
gsm_delay(1000); gsm_delay(1000); gsm_delay(1000);
void new_mess() { n1=0; while(ne[n1]!='\0') { putc(ne[n1]); n1++; } putc(0x0a); putc(0x0d); gsm_delay(1000); }
void mode() { f1 = 0; while(txt[f1]!='\0') { putc(txt[f1]); f1++; }
void uart_init() { TMOD = 0x20; TH1 = -3; SCON = 0x50; TR1 = 1; //IE = 0x90; }
/*unsigned char rx() { unsigned char rec; while(RI==0); rec = SBUF; RI = 0; return rec; }
void delete() { unsigned int d ; d=0; while(del[d]!='\0') { putc(del[d]); d++; } putc(0x0a); putc(0x0d); gsm_delay(1000);
void send_no() { unsigned int s=0; while(no[s]!='\0') { putc(no[s]);
s++;
} /*void gsm_read() { m=0; r=0; lcd_data('R'); while(rd[r]!='\0') { putc(rd[r]); r++; }
void gsm_delay(unsigned int k) { unsigned int i,j; for(i=0;i<=k;i++) for(j=0;j<=1273;j++); } void tx(unsigned char tx_data) { SBUF = tx_data; while(TI==0); TI=0; }
Right over the message field it says:
NOTE: When posting messages, use the following HTML tags to make your message easier to read and understand. For more information, refer to
try reading it
Here is a picture to help you: www.danlhenry.com/.../keil_code.png - in what way is that unclear?
