Taking the code snippet below,
char* ptr = (char*)0x0000; short size = 0x100; short sum = 0x00; do { sum += *ptr++; } while (size--)
This will cause C51 to allocate "ptr" and "size" in RAM.
MOV R3,#00H MOV R2,#00H MOV R1,#00H MOV DPTR,#pre?1251 MOVX @DPTR,PR0 MOV DPTR,#size?1252 MOV A,#01H MOVX @DPTR,A INC DPTR CLR A MOVX @DPTR,A
and everytime "size" is decremented, or "ptr" is incremented, the values are loaded back into the RAM.
Is there a way to force C51 to not use RAM but use the registers only as "ptr" and "size" will never be used anymore after that. What I mean is, is there a way to force C51 to compile to something like this,
mov dptr, #WORD0(00h) mov r4, #01h ; r4:r5 = size mov r5, #00h mov r6, #00h ; r6:r7 = sum mov r7, #00h loop: movx A, @dptr+#000h addw 006h, A ; r6:r7 += A inc dptr subw 004h, 001h ; r4:r5-- jnc loop ; add code to store r6:r7 into RAM
Any advice would be greatly appreciated. Thanks in advance.
No, it won't. Not unless you avoid turning on optimization or use a horribly wrong memory model.
Surely you're aware that no machine instruction like 'addw' exists in an 8051, right? And that, the 8051 being a so-called accumulator-based design, the target of all arithmetic machine instruction is the accumulator, not some memory address?
Oh, and if you're looking for efficient code, why are you using generic pointers?
Thanks for pointing that out but the chip I'm using supports additional extended instruction set which includes addw and it costs 3 machine cycles. Also since R0 - R7 is mapped to offset 0 to 7 of idata, I decided to access it directly.
I'm using a generic pointer because the address is a far address.
Also, the optimization option is enabled and if I never increment the pointer, the pointer will be kept in the register.
Aha. And the reason you had to keep that crucial bit of information to yourself all this time was ...?
And how were you planning on convincing the compiler that
(char *)0x0000
is something other than a not-far-at-all idata pointer?
My mistake. I just simply write a simple code snippet as example to explain what I meant. Thank you for pointing out the mistake in the sample.
However, I have no issue writing the code in ASM to optimize it. The reason for this thread is to find out whether there is a way to at least force C51 to compile to code to avoid using RAM for variable that is used within the scope/loop. If possible, forcing it to use the DPTR, EPTR, PR0, PR1 directly.
Maybe I need to clarify further,
The compiler will eventually load the pointer into dptr, eptr, pr0 or pr1 before read the value it pointed to. When I increment it in C, it will produce a code to increment the variable which is kept in the RAM, then it will load it back to either dptr, eptr, pr0 or pr1 before reading the value again. What I want is for it to increment dptr, eptr, pr0 or pr1 directly and thus avoid re-loading it back from RAM to register in each loop.
C51 produced code,
1. Allocate RAM area for pointer 2. Load pointer with address 3. Loop 3.1 Load pointer from RAM to register (dptr, eptr, pr0 or pr1) 3.2 Load value from dptr, eptr, pr0 or pr1 3.3 ... 3.4 Increment pointer in RAM 4. ...
What I want is,
1. Load address into register (dptr, eptr, pr0, or pr1) 2. Loop 2.1 Load value from dptr, eptr, pr0 or pr1 2.2 ... 2.3 Increment dptr, eptr, pr0 or pr1 3. ...
Btw, it's not just pointer. If possible, I also want variable which is used as counter to be kept in register without saving it to RAM each time it is incremented or decremented.
Sounds like you are more than happy to take on the compiler's job. Ignore the compiler then, write in assembly. It also sounds like you are not happy with the quality of the code generated by this compiler. By the way, I share your view. It would be reasonble to look for a different compiler. I hear IAR make good compilers, and they happen to have one for the 8051.
