Using the Xdata of AT89C51xD2 MCU
Hello All,
I am trying to use the xdata of the Atmel 89C51RD2 chip but it seems not to be working. I have tried most of all the suggestion I search on this forum but non seems to work. There is definitely something I am not getting write.
Here is all I have done thus far
1. Changing the Start up code as follows
IDATALEN        EQU     100H
XDATASTART      EQU     00H
XDATALEN        EQU     700H    ; 1792 size
PDATASTART      EQU     0H
PDATALEN        EQU     0H
; Standard SFR Symbols
ACC     DATA    0E0H
B       DATA    0F0H
SP      DATA    81H
DPL     DATA    82H
DPH     DATA    83H
AUXR    DATA    8EH               ; add SFR definition for AT89c51xD2
STARTUP1:
; enable on-chip xdata RAM for AT89c51xD2 MCU's
        ANL AUXR,#10H   ;AUXR/Bit 1(clear to 0 to enable on-chip XRAM and set address 1792)
2. On the option for target window, I also checked the "Use On-Chip ROM" , "Use On-Chip XRAM" & "use multiple DPTRs registers".
3. I declead most of my data's with xdata. For example
void MUL (u8 *val_1,u8 *val_2)
        u8_X R_val = 0xE1;
        u8 xdata V_val[16];
        u8_X mask_b     = 0x80;
        u16_X i; u8_X j;
        bit chk=0;
I intend to declare most of my variable into Xdata, which I did, but I still have a lot of Address space overflow. How can I fix the issue. I am of the thought that there should still be space in Data since I am storing much variables into it, especially large arrays.
I checked the Data memory in the Map file to trace out where the excess might be. I found out that the size of the Xdata and Code in a given function matches the value in the mapfile. But for the data memory, I see some increase in the size, and I can possible find how that increase came about, afterall, I did not declear any variable in the data memory in the function.
*** ERROR L107: ADDRESS SPACE OVERFLOW
    SPACE:   DATA
    SEGMENT: ?DT?_INV_?CIPHER
    LENGTH:  0006H
    SPACE:   DATA
    SEGMENT: ?DT?_MUL_?ENCRYPT
    LENGTH:  0006H
Has anyone experience this before?
