Dear Sir, We have used the example program taken from path “C:\Keil\ARM\Boards\Keil\MCB2300\RL\FlashFS\SD_File\SD_File.uV2” to create a file in MMC card interfaced to LPC2368 microcontroller using MMC card bus (Native mode). The code is working fine for 1GB MMC card. But when we are inserting 4 GB card into card slot the program is displaying “SD/MMC Init Failed” message in Flash Magic terminal window.
+-----------------------------------------------------------------------+ | SD/MMC Card File Manipulation example | + command ------------------+ function ---------------------------------+ | CAP "fname" [/A] | captures serial data to a file | | | [/A option appends data to a file] | | FILL "fname" [nnnn] | create a file filled with text | | | [nnnn - number of lines, default=1000] | | TYPE "fname" | displays the content of a text file | | REN "fname1" "fname2" | renames a file 'fname1' to 'fname2' | | COPY "fin" ["fin2"] "fout"| copies a file 'fin' to 'fout' file | | | ['fin2' option merges 'fin' and 'fin2'] | | DEL "fname" | deletes a file | | DIR "[mask]" | displays a list of files in the directory | | FORMAT [label [/FAT32]] | formats Flash Memory Card | | | [/FAT32 option selects FAT32 file system] | | HELP or ? | displays this help | +---------------------------+-------------------------------------------+
SD/MMC Init Failed Insert Memory card and press key...
We have used the above signal lines to interface the MMC card with LPC2368. Please help us in solving this problem. The MMC card used is “micro SDHC – 4GB”
Waiting for your reply
Thanks in advance Regards K.Surendar reddy surenderreddy333@gmail.com
http://www.keil.com/forum/20828/
