I'm testing some ideas using the EC++ compiler for C166. I've found that when I want to call a C function from a C++ file I have to prototype the function
extern "C" void myfunc(void);
I'm struggling to find how to call a function in a C++ from a C file. I can see from the m66 file that a function in a cpp file gets named myfunc__Fv. I can prototype my function
void myfunc__Fv(void);
and it compiles OK. Is there a directive that tells the compiler to use the correct naming convention?
(Why? I have a test project which is currently built in plain C. I want to try out some extensions to it in C++. In main have called a function InitCpp which is implemented in InitCpp.cpp - a c++ file. This initialises the mempool, calls __sti__init__ and defines new and delete. However I can't call InitCpp, I get an unresolved external InitCpp since the EC++ compiler calls it InitCpp__Fv. I can fudge it by prototyping as above but wanted to know if there was a way of doing this by design. I cannot find extern "C" in the help since search finds all occurances of C when I try. I was hoping that the manual page describing extern "C" would offer whatever extern "CPP" is. I suspect there nothing unless Keil have modified the plain C complier to support the C++ calling convention.)
Thanks for any ideas A
IDE-Version: µVision V4.00a Copyright (c) Keil Elektronik GmbH / Keil Software, Inc. 1995 - 2009
License Information: Alec James Talaris LIC=xxxxx-xxxxx-xxxxx-xxxxx-xxxxx-xxxxx
Tool Version Numbers: Toolchain: PK166 Prof. Developers Kit Version: 7.00 Toolchain Path: d:\Keil\C166\BIN\ EC++ Compiler: EC166.Exe V1.09d C Compiler: C166.Exe V7.00 Assembler: A166.Exe V5.33 Linker/Locator: L166.Exe V5.25 Librarian: LIB166.Exe V4.26 Hex Converter: OH166.Exe V4.7a CPU DLL: S166.DLL V3.74 Dialog DLL: D167.DLL V2.52
You really shouldn't have posted your license number. Don't know why you did - the license doesn't have anything with your source code to do.
C++ can call C. C can't call C++.
But you can create a C++ function with C calling convention (remember your extern "C"), making it possible for a C function to call it.
The other alternative is to compile everything (C and C++ files) in C++ mode. This works unless your code contains any code construct that is only valid in C - after all, C++ is no longer a strict superset of C. If the system header files doesn't contain extern "C" in them, you may have to modify your own code to do:
extern "C" { #include "a_header_file_for_a_c_library.h" }
just to make sure that your code will try the C calling convention. But all good C libraries should only have header files that turns on this inside the header files if they detect C++ compilation.
Thats fixed it for me, I define my InitCpp function as EXTERN_C in the cpp file and can call it OK from my main function. Thanks
(I copied the tool set version info from the uvison about box using "copy info" to give tool version numbers, I didn't notice...)
See also this article:
http://www.keil.com/support/docs/3223.htm
