CAN Bus I try to use an exemple by KEIL, but when i try to debug it doesn't work,
my main is :
"/******************** (C) COPYRIGHT 2007 STMicroelectronics ******************** * File Name : main.c * Author : MCD Application Team * Version : V2.0 * Date : 12/07/2007 * Description : Main program body ******************************************************************************** * THE PRESENT SOFTWARE WHICH IS FOR GUIDANCE ONLY AIMS AT PROVIDING CUSTOMERS WITH * CODING INFORMATION REGARDING THEIR PRODUCTS IN ORDER FOR THEM TO SAVE TIME. AS * A RESULT, STMICROELECTRONICS SHALL NOT BE HELD LIABLE FOR ANY DIRECT, INDIRECT * OR CONSEQUENTIAL DAMAGES WITH RESPECT TO ANY CLAIMS ARISING FROM THE CONTENT * OF SUCH SOFTWARE AND/OR THE USE MADE BY CUSTOMERS OF THE CODING INFORMATION * CONTAINED HEREIN IN CONNECTION WITH THEIR PRODUCTS. *******************************************************************************/ /* Standard include ----------------------------------------------------------*/ #include "91x_lib.h" /* Include of other module interface headers ---------------------------------*/ /* Local includes ------------------------------------------------------------*/ /* Private typedef -----------------------------------------------------------*/ /* Private define ------------------------------------------------------------*/ /* Private macro -------------------------------------------------------------*/ /* Private variables ---------------------------------------------------------*/ canmsg RxCanMsg; canmsg CanMsg; GPIO_InitTypeDef GPIO_InitStructure; CAN_InitTypeDef CAN_InitStructure; /* buffer for receive messages */ canmsg RxCanMsg; /* used message object numbers */ enum { CAN_TX_MSGOBJ = 0, CAN_RX_MSGOBJ = 1 }; /* array of pre-defined transmit messages */ canmsg TxCanMsg[3] = { { CAN_STD_ID, 0x123, 4, { 0x01, 0x02, 0x04, 0x08 } }, { CAN_STD_ID, 0x321, 4, { 0xAA, 0x55, 0xAA, 0x55 } }, { CAN_EXT_ID, 0x12345678, 8, { 0x10, 0x11, 0x12, 0x13, 0x14, 0x15, 0x16, 0x17 } } }; /* Private functions ---------------------------------------------------------*/ void SCU_Configuration(void) { SCU_MCLKSourceConfig(SCU_MCLK_OSC); SCU_PCLKDivisorConfig(SCU_PCLK_Div2); SCU_PLLFactorsConfig(128,25,4); SCU_PLLCmd(ENABLE); SCU_MCLKSourceConfig(SCU_MCLK_PLL); SCU_APBPeriphClockConfig(__CAN, ENABLE); SCU_APBPeriphClockConfig(__GPIO0, ENABLE); SCU_APBPeriphClockConfig(__GPIO1, ENABLE); SCU_APBPeriphClockConfig(__GPIO3, ENABLE); SCU_APBPeriphClockConfig(__GPIO5, ENABLE); SCU_APBPeriphClockConfig(__GPIO9, ENABLE); SCU_AHBPeriphClockConfig(__VIC, ENABLE); SCU_APBPeriphReset(__CAN, DISABLE); SCU_APBPeriphReset(__GPIO0, DISABLE); SCU_APBPeriphReset(__GPIO1, DISABLE); SCU_APBPeriphReset(__GPIO3, DISABLE); SCU_APBPeriphReset(__GPIO5, DISABLE); SCU_APBPeriphReset(__GPIO9, DISABLE); SCU_AHBPeriphReset(__VIC, DISABLE); } void IO_Init(void) { /* P5.0 alternate input 1, CAN_RX pin 12*/ GPIO_StructInit(&GPIO_InitStructure); GPIO_InitStructure.GPIO_Pin=GPIO_Pin_0; GPIO_InitStructure.GPIO_Direction=GPIO_PinInput; GPIO_InitStructure.GPIO_IPInputConnected=GPIO_IPInputConnected_Enable; GPIO_InitStructure.GPIO_Alternate=GPIO_InputAlt1; GPIO_Init(GPIO5,&GPIO_InitStructure); /* P5.0 alternate output 2, CAN_TX */ GPIO_StructInit(&GPIO_InitStructure); GPIO_InitStructure.GPIO_Pin=GPIO_Pin_0; GPIO_InitStructure.GPIO_Direction=GPIO_PinOutput; GPIO_InitStructure.GPIO_Type=GPIO_Type_PushPull; GPIO_InitStructure.GPIO_IPInputConnected=GPIO_IPInputConnected_Disable; GPIO_InitStructure.GPIO_Alternate=GPIO_OutputAlt2; GPIO_Init(GPIO5,&GPIO_InitStructure); } void CAN_Com_LoopBack(void) { /* initialize the CAN at a standard bitrate, interrupts disabled */ CAN_InitStructure.CAN_ConfigParameters=0x0; CAN_InitStructure.CAN_Bitrate=CAN_BITRATE_1M; CAN_Init(&CAN_InitStructure); /* switch into Loopback+Silent mode (self-test) */ CAN_EnterTestMode(CAN_TESTR_LBACK | CAN_TESTR_SILENT); /* configure the message objects */ CAN_SetUnusedAllMsgObj(); CAN_SetTxMsgObj(CAN_TX_MSGOBJ, CAN_STD_ID, DISABLE); CAN_SetRxMsgObj(CAN_RX_MSGOBJ, CAN_STD_ID, 0, CAN_LAST_STD_ID, TRUE); /* Send the pre-defined answer */ CAN_SendMessage(CAN_TX_MSGOBJ, &TxCanMsg[1]); /* wait until end of transmission */ CAN_WaitEndOfTx(); /* wait for reception of a data frame */ while (!CAN_ReceiveMessage(CAN_RX_MSGOBJ, FALSE, &RxCanMsg)) { /*Add Timer*/ } /* Test Received Msg */ if((RxCanMsg.IdType == CAN_STD_ID)&&(RxCanMsg.Id == 0x321)&&(RxCanMsg.Dlc == 4) &&(RxCanMsg.Data[0]==0xAA)&&(RxCanMsg.Data[1]==0x55)&&(RxCanMsg.Data[2]==0xAA)&&(RxCanMsg.Data[3]==0x55)){ /*Received Msg OK*/ } else { /*Received Msg KO*/ } /* release the message objects */ CAN_ReleaseTxMessage(CAN_TX_MSGOBJ); CAN_ReleaseRxMessage(CAN_RX_MSGOBJ); /* switch back into Normal mode */ CAN_LeaveTestMode(); } /******************************************************************************* * Function Name : main * Description : Main program * Input : None * Output : None * Return : None *******************************************************************************/ int main(void) { SCU_Configuration();/*PCLK=8MHz*/ IO_Init(); /* CAN tests */ CAN_Com_LoopBack();/* send and receive some frame */ while(1); } /******************* (C) COPYRIGHT 2007 STMicroelectronics *****END OF FILE****/
Best regards
Thanks for the info.
I try to use an exemple by KEIL, [...]
Color me confused but:
Does kind of not look like the copyright mentions Keil.
* THE PRESENT SOFTWARE WHICH IS FOR GUIDANCE ONLY AIMS AT PROVIDING CUSTOMERS WITH * CODING INFORMATION REGARDING THEIR PRODUCTS IN ORDER FOR THEM TO SAVE TIME. AS * A RESULT, STMICROELECTRONICS SHALL NOT BE HELD LIABLE [...]
Doesn't look like Keil either.
If Keil is just distributing an example from ST - maybe you should check if ST have the same example with a little newer copyright year. Or maybe you should see if ST can help out with the problem.
By the way "doesn't work" isn't really one of the better error descriptions.
when i debug, the message object to transmit is correctly configured but nothing is received.
