hi. i got a problem in compiling this program.can anyone help me???i tried so many times..but still got error..can anyone help me what is wrong and what to be change.tq.here,is the program:
#include<reg51.h> #include <intrins.h> #include"lcdbusy.h"
#define tensec 150 void ext_init(void); void timerinterrupt_init(); // calling the timer and exter interrupt init functions void timer0_init();
void delay(unsigned int ); void start_poring(void); //////////////////*****************************************************//////////// sbit sw1=P2^0; // assign the p2.0 for switch0 sbit sw2=P2^1; // assign the p2.1 for switch1
sbit MOT_FWD=P0^0; sbit MOT_REV=P0^1;
/////////////////////*****************************************************//////// bit counterflag=0;
volatile bit solaniodflag=0,timer_flag=0; unsigned char val=0,location=0; volatile unsigned int count_ON=0; /*******************************************************************************************/ void main() { timer0_init(); ext_init(); lcd_init(); message(0x80,"INJUCTION PUMP"); message(0xc0,"sw1 10ml, sw2 15ml"); delay(50); while(1) { if(sw1==0) { for(val=0;val<5;val++) { MOT_FWD=0; delay(2); MOT_REV=1; } }
if(sw2==0) { for(val=0;val<10;val++) { MOT_FWD=0; delay(2); MOT_REV=1; } break; } if(solaniodflag==1) { ET0=1; // enable the timer interrupt flag bit in the IE register TR0=1; //Start the Timer solaniodflag=0; // clearing the interrupt flag bit timer_flag=1; start_poring(); } if(timer_flag==1) { while(1) { start_poring(); if(count_ON>=tensec) { TR0=0; //Timer OFF ET0=0; // Disable the timer interrupt timer_flag=0; count_ON=0; P0=0x00; break; } } } } }
void timer0_init(void) { TL0=0XFD; TH0=0X4B; // timer registewr value for 50 msec }
void timer0(void) interrupt 1 { TR0=0; TL0=0XFD; TH0=0X4B; TR0=1; count_ON++;
} /***************external interrupt intializing function*********************************/ void ext_init() { EA=1; EX1=1; IT1=1; } void ext1(void) interrupt 2 {
solaniodflag=1; }
void start_poring(void) { val=0; MOT_REV=0; while(1) { MOT_FWD=1; delay(4); MOT_REV=0; delay(20); val++; if(val==150) break; } }
