I'm using RL-FlashFS with 2 file systems one on a USB MSD (FAT) the other on NOR Flash (EFS).
I've implmented the two time functions:
fs_get_time and fs_get_date.
These appear to be working as expected for the USB FAT file system but it seems the EFS does not call these functions.
I can't find any reference that says the EFS does not use a time stamp.
M
Does anyone have any ideas/experience on this?
From the RL-ARM User's Guide section on EFS:
Note
Embedded File System does not support directories or folders. File names are preprocessed to remove the path information for non-FAT file systems. The timestamp information for the file is not supported.
So unfortunately you don't get support for file time/date stamps on your EFS volume.
¦If you can't does this not cause a problem with the webserver with regards to browser caching?
This I cannot help with.
