hi..nice to meet u all..i'm hidayah..i need a help about my project.i'm using microcontroller 8051, P89V51RD2 BY NXP PHILIPS.my project quite same to this link ece-projects.blogspot.com/.../injection-pump-using-microcontroller.html u can download a full report to see the whole work. For my problem i already tried do the compiling of the program,but i can't. it says get error and cannot read #include<reg51.h>. Furthermore i can't see very clearly of circuit diagram in the report to draw in proteus. So, i need your help and teach because the dateline is coming..thank you.
Best regards, nur hidayah
What kind of help do you need, exactly?
i'm having the problem about the circuit in the report because the circuit is not very clear to draw in proteus. Furthermore, i tried to compile the program using keil software(microvision4) and can't get the result. it says that #include<reg51.h> cannot defined. i'm very new in microcontroller, so i need a help..
So what do you compile with? You seems to have confused C51 and C251.
By the way - it just fails? No indications at all what goes wrong?
im using 8051, P89V51RD2 BY NXP PHILIPS. maybe it cannot defined my program. can u show me a step by step how to do a compile..by the way i'm using c language..
http://www.keil.com/c51/man/c51.htm
