Hi
I've used At91sam7x512 and keil sample codes for TCP connection but here is a kind of problem when I try to disconnect my board in my tcp_callback routine I'll get TCP_EVT_CLOSE condition and here I called tcp_close(soc)
when I use tcp_get_state before tcp_close the result is 10 (TCP_STATE_CONNECT) and after that it's 255 (!!!)
and if I wait for 2 or more minutes my tcp_callback have been called again but with TCP_EVT_ABORT condition.
during this time gap, I'm in listening mode but nobody can connect to my device.
below code is a part of my work and I used printf to get state of tcp in different positions:
case TCP_EVT_CLOSE: printf("1:%d\r\n",tcp_get_state(soc)); tcp_close(soc); tcp_release_cocket(soc); printf("2:%d\r\n",tcp_get_state(soc)); initializetcp(); . . . case TCP_EVT_ABORT: printf("3:%d\r\n",tcp_get_state(soc)); tcp_abort(soc); tcp_release_cocket(soc); printf("4:%d\r\n",tcp_get_state(soc)); initializetcp(); . . .
and in initializetcp routine I try to get socket and listen. and I've used tcp_abort instead of tcp_close in TCP_EVT_CLOSE condition but they were the same and the problem was exist
and I've got such a result from hyperteminal:
1:10 2:255
(after 2 minute)
3:8 4:255
although when I try to close my program in PC there is no any problem but when my application program throw an exception such problem will occur.
what's going wrong here?
thanks in advance
I don't recall the details right now, but this must be related to specified/desired behavior of TCP/IP intended to allow a delayed ACK to arrive after disconnect. Check the web for details.
Maybe this can help:
www.tcpipguide.com/.../t_TCPOperationalOverviewandtheTCPFiniteStateMachineF-2.htm
I think you are looking at a "TIME-WAIT" state.
Don't use "tcp_abort" unless you _really_ have to!
I think this might be more related to a TCPnet limitation where you must be VERY careful what you call from within a TCP callback. Especially the part where you say:
"...in initializetcp routine I try to get socket and listen."
from within your TCP_EVT_CLOSE condition.
The details concerning the ability to do is were (and possibly still are still) very sketchy.
When I first encountered it, the support team unfortunately were unable to provide me with further details and simply said that their documentation needed updating!
I would suggest you move all but the most basic code out of the callback into the main TCP processing task.
Hi all
I tried to move get socket routine to another place (to main task) and connection will close as well
thanks a lot IB Shy
but here is another problem with my board
when the cable be unplugged link indicator of PHY (DP83848) will show me that the cable was unplugged very fast but there is no any act on software till timeout occur.
how can I aware such an event very fast?
although I found somethings about keepalive routine but I can not send zero length packet. (tcp_send give me an error)
is keepalive essential for TCP connection? if yes how?
"when the cable be unplugged link indicator of PHY (DP83848) will show me that the cable was unplugged very fast but there is no any act on software till timeout occur."
Most (if not all) PHYs have the ability to check the link state - You can poll the status and determine whether the cable connection is good. Check the PHY documentation for details.
I don't know why but I tried it and always give me zero as a result and it's nonsense.
but thanks I'll try it more and more... but is there any solution in RL-ARM? or not?
thanks a lot
"...but is there any solution in RL-ARM? or not?"
None of which I'm aware.
You may want to look at keepalives.
You may want to look at sending periodic packets as part of your communication protocols.
Neither of these will tell you of:
1) a cable disconnection very soon after it occurs 2) brief intermittent communication problems
In my opinion, the best way is to interrogate the PHY.
thanks IB Shy
I tried to read PHY status register ... but it gave me zero as a result ... but something here was dropped out and that was setting PHY to MDI enable... I've forgot it and now with such a routine works properly:
unsigned short int status; MDI_Enable(); status=Read_PHY(0x10); if ((status & 1)) printf("lan is connected\r\n"); else printf("lan has been disconnected\r\n"); MDI_Disable();
here, I could recognize LAN link status very fast.
and about keepalive: Do you agree with keepalive method ,or not? because I've read RFC for TCP and keepalive in this document was not a good method.
I need to know the connection is still alive or not.
with these methods which you said (reading the PHY status and moving the port closing routine to main process), connection is reliable enough but I want to prevent any unexpected problems.
How can I send a TCP packet with zero lenght of data?
thank thank thank
"Do you agree with keepalive method ,or not?"
It really does depend on the requirements. For a connection that is expected to stay alive for a long time with long gaps in the communication, it can be useful. If data is being sent/received with gaps shorter than the keepalive rate then there is little point in having the keepalives. If you want the connection to tidily close when inactive, then keepalives would need to be disabled anyway.
"How can I send a TCP packet with zero lenght of data?"
As far as I am aware, you cannot send a TCP packet of zero length using TCPnet, but that should not be a requirement ...
Technically, when you send data from an application over TCP it is in a stream and the fact that the data is sent in packets should not be important.
