hi I am using 89c51. for using serial port I am using these commands
SCON = 0x50; /* SCON: mode 1, 8-bit UART, enable rcvr */ TMOD = 0x20; /* TMOD: timer 1, mode 2, 8-bit reload */ TH1 = 0xfd; /* TH1: reload value for 9600 baud */ TR1 = 1; /* TR1: timer 1 run */
these are working correctly ------------ but in main function i am calling 2 functions
for example ---------------------
void main() { while(1) { if(RI) { GetData(); } if(??????????) { DisplayData(); } } }
At the location "??????????" I want to call the DisplayData() after a specific clock period, for example after every 1000 clocks. is it possible to set the timer0 of 89c51 for this purpose.
Set up a timer to generate an interrupt at the required rate;
In the timer's Interrupt Service Routine, set a flag;
In the main loop, test this flag
void main() { while(1) { if(RI) { GetData(); } if( time_to_display_data ) { // The flag is set - it's time to display the data DisplayData(); // Clear the flag ready for next time... time_to_display_data = 0; } } }
Simples!
Note that the above is not specific to the 8051 - the approach would work for any processor with a timer that can generate an interrupt.
