Dear All,
I have used the HID code available in Keil Library. I am able to transfer one one byte Using control transfer but Now as per requirements and Specifications I need to transmit data that is more than 64 bytes..need to enable Bulk transfer can somebody..post some precious and valued Suggestions for How to enable bulk tranfer for LPC2378.
Thanks And Reagrds Hrishikesh A Choudhary.
use the MSC example in your Keil installation so you don't need nothing on the host side (if the host is a PC!). Or use the CDC so you need only an *.inf File.
Dear Sir,
Thanks for your reply...Can u post some Link that will help me in testing the Bulk transfer data..which i can Install on the Host side.
Thanks and Regards Hrishikesh.
with the HID-Class it is impossible to transmit in bulk transfer. You have to use the CDC or MSC. Or you program your own class.
