hello,
this the version of my keil µvision sofware:
IDE-Version: µVision3 V3.51
Tool Version Numbers: Toolchain Path: C:\Keil\C51\BIN\ C Compiler: C51.Exe V8.08 Assembler: A51.Exe V8.00d Linker/Locator: BL51.Exe V6.05 Librarian: LIB51.Exe V4.24 Hex Converter: OH51.Exe V2.6 CPU DLL: S8051.DLL V3.11 Dialog DLL: D500.DLL V2.46
my problem: I have a wrong compilation with the use a global bdata variable.
here is my code in multiple file:
global.c
#include global.h unsigned char bdata buffer; sbit buffer_0 = buffer^0; sbit buffer_1 = buffer^1; sbit buffer_2 = buffer^2; sbit buffer_3 = buffer^3; sbit buffer_4 = buffer^4; sbit buffer_5 = buffer^5; sbit buffer_6 = buffer^6; sbit buffer_7 = buffer^7; xdata struct struct_plateau plateau[6] _at_ 0x4001;
global.h
extern unsigned char bdata buffer; extern bit buffer_0; extern bit buffer_1; extern bit buffer_2; extern bit buffer_3; extern bit buffer_4; extern bit buffer_5; extern bit buffer_6; extern bit buffer_7; extern xdata struct struct_plateau plateau[6]; struct struct_plateau { unsigned char lampe_tilt_ou_bonus; unsigned char lampe_carte_et_stop; };
reglage.c
#include global.h void test_switch_bandeau_et_lampe_bandeau_et_tilt () { buffer = memorisation_lecture_switch_carte; plateau[0].lampe_carte_et_stop = buffer_0; //ligne 1 plateau[1].lampe_carte_et_stop = buffer_1; //ligne 2 plateau[2].lampe_carte_et_stop = buffer_2; //ligne 3 plateau[3].lampe_carte_et_stop = buffer_3; //ligne 4 plateau[4].lampe_carte_et_stop = buffer_4; //ligne 5 plateau[5].lampe_carte_et_stop = buffer_5; //ligne 6 buffer = memorisation_lecture_switch_stop; //don't compile this ligne 7 plateau[0].lampe_tilt_ou_bonus = buffer_0; //ligne 8 plateau[1].lampe_tilt_ou_bonus = buffer_1; //ligne 9 plateau[2].lampe_tilt_ou_bonus = buffer_2; //ligne 10 plateau[3].lampe_tilt_ou_bonus = buffer_3; //ligne 11 plateau[4].lampe_tilt_ou_bonus = buffer_4; //ligne 12 plateau[5].lampe_tilt_ou_bonus = buffer_5; //ligne 13 }
the problem is that the compilator don't take a look of the ligne 7. I have take a look in the desasembly file and It save the result of the ligne 1 to 6 in register R0 to R5 and restore this value in ligne 8 to 13.
I have try this second solution and all is ok
void test_switch_bandeau_et_lampe_bandeau_et_tilt () { unsigned char i; buffer = memorisation_lecture_switch_carte; for (i=0 ; i<6; i++) { if (buffer_0 == 0) { plateau[i].lampe_carte_et_stop = 0; } else { plateau[i].lampe_carte_et_stop = 1; } buffer >>= 1; } buffer = memorisation_lecture_switch_stop; for (i=0; i<6; i++) { if (buffer_0 == 0) { plateau[i].lampe_tilt_ou_bonus = 0; } else { plateau[i].lampe_tilt_ou_bonus = 1; } buffer >>= 1; } }
I have also try to declare directly de buffer in the reglage.c file without extern and all is ok, I have just this problem if the buffer_0 to buffer_7 are declare with extern in .h file.
what do you think about this ?
