how do I check #pragma directives
Hello ! I have a some quetions.
I my project i write some math(on Assembler) library for using in C and Assembler.
I have some function, in C this function can be defined:
extern signed long add32(signed long var1, signed long var2)
of course, this mean I have to respectively describe the function in assembler:
;---------- Object name ---------------
NAME ADD32        ; Obj. name
;---------- Segment declaration -------
?PR?_add32?ADD32 SEGMENT CODE                   ; Segment defenition
?DT?_add32?ADD32 SEGMENT DATA OVERLAYABLE       ; Segment defenition for long var's.
;---------- Public symbols ------------
PUBLIC ?_add32?BYTE                             ; Public symbol for long var's
PUBLIC _add32                                   ; Public function symbol
;---------- Vars defenition -----------
RSEG ?DT?_add32?ADD32
?_add32?BYTE:
ORG 04H
OP_BYTE:                 ds 04H                 ; Second operand memory allocate
;---------- Function code  ------------
RSEG ?PR?_add32?ADD32
_add32:
                clr C                           ; clr Carry
                mov  A,R7                       ; load ACC with LSB first op.
                ADD  A,OP_BYTE +03H             ; ADD LSB second op.
                mov  R7,A                       ; save result to R7
                mov  A,R6                       ; load ACC with next byte first op.
                ADDC A,OP_BYTE +02H             ; ADD next byte second op. + Carry
                mov  R6,A                       ; save result to R7
                mov  A,R5                       ; load ACC with next byte first op.
                ADDC A,OP_BYTE +01H             ; ADD next byte second op. + Carry
                mov  R5,A                       ; save result to R7
                mov  A,R4                       ; load ACC with MSB first op.
                ADDC A,OP_BYTE +00H             ; ADDC MSB second op. + Carry
                mov  R4,A                       ; save result to R6
end_add32:
                ret
END
and
;---------- Vars defenition ----------- RSEG ?DT?_add32?ADD32 ?_add32?BYTE: ORG 04H OP_BYTE: ds 04H ; Second operand memory allocate
this segment must be declared for passing variable in function with type long.
When i define ,example:
#pragma REGPARMS
this function working normaly, first long var placed to R4& R5& R6& R7, second lond var placed direc to memory segment ?DT?_add32?ADD32 with offset four bytes.
BUT when I want to like don't use register and pass all parametrs in memory, if i define
#pragma NOREGPARMS
first long var placed to ?DT?_add32?ADD32 without offset , second lond var placed direc to memory segment ?DT?_add32?ADD32 with offset four bytes, and my function don't work.
Quetions:
Possible to determine at compile time which #pragma directives are set, and on this corect source code.
This function only example, of course no need use this function in C.
Sorry for my english.:)
With best regards Artem Gusev.
Thanks for all.
