integrating a GSM modem with ARM7
i am using an ARM7 LPC2129 microcontroller for a driver fatigue detection system based on grip sensors.Once the sensors are triggered, the location of the vehicle(from GPS) is sent to a control room through a GSM modem. i need to add a webcam to the system that can take a short clip and then transmit it through the GSM modem. Can anyone help me on how to integrate a webcam with the ARM7 LPC 2129 and program it to take a short clip for 30 seconds and then send it through the GSM modem as MMS. I am using a Wavecom Q2406 GSM modem
  • Note that Wavecom is now Sierra Wireless.
    Do you really need the ARM7 - have you considered using Open-AT?
    Note that Sierra Wireless have an application note about MMS...
    If you're not using Open-AT, then the Q2406 is effectively just a standard, dumb, GSM modem - Google will find you loads of info for controlling standard, dumb, GSM modems...
    Google will also find you loads of info for controlling cameras - there's even a thread right here: http://www.keil.com/forum/18202
    Specifically for finding open-source code, try: http://codesearch.google.com
    Other search engines are available.
