Hi i am currently working on the mcb2300. the timer0 is used.Iam just toggling the led ports.In the simulation i am able to get the output but regarding the hardware i am not able to see the toggling of the led's.
Here i am posting the code snippet.kindly help me to solve the problem.
Thanks in advance....
#include<stdio.h> #include <LPC23XX.H> void T0isr(void); void time_init(void); void delay(void); unsigned int value; void led_init(void); void delay(void); int main(void) { PLLCON=0x00; CLKSRCSEL=0x01; CCLKCFG=0x03; PCONP=0x00000002; time_init(); T0PR=0x0000C6C0; T0TCR=0x02; T0MCR=0x0003; T0MR0=0x00000005; T0TCR=0x01; //T0CR0=0x01; T0TC=0x00; //T0CTCR=0x00; T0PC=0x00; FIO2DIR=0x000000FF; FIO2MASK=0x00000000; FIO2SET=0x00000055; FIO2CLR=0x000000AA; T0IR=0x01; VICVectAddr4 = (unsigned)T0isr; VICVectPriority4=0X00000024; //Enable the interrupt VICIntEnable |= 0x00000010; while(1); } void time_init() { PCLKSEL0=0x0000000C; PINSEL3=0x03000000; PINMODE3=0x00000000; } void T0isr(void) { FIO2CLR = 0x000000AA; FIO2SET = 0x00000055; T0IR |= 0x00000001; //Dummy write to signal end of interrupt VICVectAddr = 0x00000000; }
I think you shoud add the keyword "__irq" to you interrupt routine.
Like this,
void T0isr(void) __irq; .... void T0isr(void) __irq { .... }
I tried with that also but.It does not working...
