I want generate one binary output file for an image containing multiple load regions. So I can use it for my bootloader.
I use the --bincombined option like descriped here: http://www.keil.com/support/man/docs/armutil/armutil_cacfhhha.htm My statement in the Keil environment is: fromelf --bincombined .\Hardwaretest.axf -o .\Hardwaretest.bin but this Statement brings me an error: Fatal error: Q3900U: Unrecognized option '--bincombined'. If I use --bin instead of --bincombined everything works (but with multiple output). Can it be that I have an old version of fromelf.exe? My Version: ARM FromELF, RVCT3.1 [Build 939] for uVision [Standard] So anybody can help me? Thank you very much
I use the latest released "fromelf" for the same purpose, and I don't have this problem.
Ok,
thank you very much for the fast answer! I don't want buy a new linces only for this option. So I have search another solution. Actually I want only use a fixed address for bootloader Version and App. Version. So I thought I creat two sections. Everything works fine only bincombined not! So maybe I put the fixed address in the starting address and test with one section. Thanks again!
