Hello everybody! I'm quite new to programing with C for 8051, and have a question about writing to Xdata: I'm to trying to store large amount of inforamtion. when I send to stored byte to SBUF to send to my PC usuing UART, I don't get the expected result. instead, the recieved character is the address in which the data is stored, and not the data itself. my code is:
#include <reg51.h> #include <absacc.h> void config (void); void delay(unsigned int itime); void serial_write(unsigned char t); sbit LED=P3^4; xdata unsigned char TEST='a' ; // _at_ 0x00; void main(void) { unsigned char i=0; //TEST='a'; config (); TR1 = '1'; for (i=0;i<=25;i++) { serial_write(TEST); } } void config (void) { TMOD=0x20; //settings for TIMER1 TH1=0xEE; //setting value for TIMER1 assuming SCON=0 SCON=0x50; //settings for UART EA=1; EX0=1; } void delay(unsigned int itime) { int i,j; for (i=0;i<itime;i++) for (j=0;j<1275;j++); } void serial_write(unsigned char t) { SBUF=t; while(TI==0); TI=0; delay(1000); LED=!LED; }
if I put the note: "// _at_ 0x00;" to be in the code, I get the address in which I saved the data on my PC in hyperterminal, instead of getting the saved data (i.e. 'a').
what is wrong?
another question: to save large amount of data, should I preffer saving in Xdata or in the Code section? does the data in Xdata deleted whenever there's a power off ?
my micro processor is ADUC841 with crystal of 11.0592 Mhz. thanks for your help!
I'm quite new to programing with C for 8051 you need to read "the 8051 bible" www.8052.com/.../120112
Most of this documentation is hardware related... I know a thing or two in programming, and my question is mainly about the XDATA part.
As I try to write to the 841 external memory and send it to my computer throught UART, I always get "00" instead of the actual data in the variable that was sent.
Is the problem in the code? or is it compiler related and I have done something wrong?
Can anyone help me and tell why does it happen ? thanks.
What happens if you do:
serial_write('a');
Jon
