struct tag { char a:7; char b:1; }; unsigned char foo(void) { struct tag test; test.b = 1; return test.b; } void main(void) { char dat; if(foo() == 1)// ***foo return 0x80 not 0x01 { dat = 2; } while(1); }
17: void main(void) 18: { 19: char dat; 20: 21: if(foo() == 1) C:0x000F 12001A LCALL foo(C:001A) C:0x0012 BF0103 CJNE R7,#0x01,C:0018 22: { 23: dat = 2; C:0x0015 750802 MOV 0x08,#0x02 24: } C:0x0018 80FE SJMP C:0018 8: unsigned char foo(void) 9: { 10: struct tag test; 11: 12: test.b = 1; 13: C:0x001A 430980 ORL 0x09,#P0(0x80) 14: return test.b; C:0x001D E509 MOV A,0x09 C:0x001F 5480 ANL A,#P0(0x80) C:0x0021 FF MOV R7,A 15: }
What is the sign-ness of char for your build?
Assuming a char is signed then:
You have an element with a width of 1 bit as a signed char. Does a 1 bit twos complement value make any sense?
When you return the value it is being converted to an unsigned char. What conversion will occur?
Likely that you intended your 1 bit variable to be unsigned. Try it.
struct tag { unsigned char a:7; unsigned char b:1; }; unsigned char foo(void) { struct tag test; test.b = 1; return test.b; } void main(void) { unsigned char dat; if(foo() == 1)// ***foo return 0x80 not 0x01 { dat = 2; } while(1); }
17: void main(void) 18: { 19: unsigned char dat; 20: 21: if(foo() == 1)// ***foo return 0x80 not 0x01 C:0x000F 12001A LCALL foo(C:001A) C:0x0012 BF0103 CJNE R7,#0x01,C:0018 22: { 23: dat = 2; C:0x0015 750802 MOV 0x08,#0x02 24: } C:0x0018 80FE SJMP C:0018 8: unsigned char foo(void) 9: { 10: struct tag test; 11: 12: test.b = 1; 13: C:0x001A 430980 ORL 0x09,#P0(0x80) 14: return test.b; C:0x001D E509 MOV A,0x09 C:0x001F 5480 ANL A,#P0(0x80) C:0x0021 FF MOV R7,A 15: }
THE RESULT IS THE SAME!
Keil support should be interested in this. Contact them.
