syntax error
i am working on following project.
& its showing me some errors... & i am unable to remove them... please help me out...
program:-
/*HEADER FILES*/
#include<reg51.h>
#include<string.h>
/*LCD PIN CONNECTIONS*/
#define lcd P0
sbit rs=P0^1;
sbit en=P0^3;
/*LCD FUNCTIONS DECLARATIONS*/
void init_lcd(void);
void cmd_lcd(unsigned char);
void data_lcd(unsigned char);
void str_lcd(unsigned char *);
void Delay_ms(unsigned int);
/*KEYPAD PIN CONNECTIONS*/
sbit row0=P2^3;
sbit row1=P2^5;
sbit row2=P2^6;
sbit row3=P2^0;
sbit col0=P2^4;
sbit col1=P2^2;
sbit col2=P2^1;
/*MOTOR PIN CONNECTIONS*/
sbit M1=P1^0;
sbit M2=P1^5;
/*BUZZER PIN CONNECTION*/
sbit BUZZER=P1^2;
/*VARIABLES DECLARATION*/
unsigned char i,j;
unsigned char colval,rowval,pwdchange;
unsigned char pwd[15],temp[],str1[]="12345";
unsigned char keypad[4][3]={'1','2','3','4','5','6','7','8','9','*','0','#',};
/*PASSWORD FUNCTION DECLARATION*/
void password(void);
/*KEYPAD FUNCTION DECLARATION*/
unsigned char key(void);
/*MAIN FUNCTION*/
main()
    unsigned char k=0;
    BUZZER=0;           //BUZZER OFF
        M1=M2=0;                //MOTOR OFF
        init_lcd();             //LCD INITIALIZATION FUNCTION CALLING
        str_lcd("ENTER PASSWORD:");           //DISPLAY STRING ON LCD
        while(1)
                cmd_lcd(0xc0);          //2ND LINE DISPLAY
                password();                     //PASSWORD FUNCTION CALLING
                if(pwdchange)
                        pwdchange=0;
                        continue;
                if(!strcmp(str1,pwd))           //COMPARING WITH 1ST PASSWORD
                        cmd_lcd(0xc0);
                        str_lcd("DOOR OPEN");
                        M1=0;           //MOTOR RUNS IN FORWARD DIRECTION
                        M2=1;
                        Delay_ms(30);                   //30 MILLISECONDS DELAY
                        cmd_lcd(0xc0);
                        str_lcd("             ");
                        M1=0;                                   //MOTOR OFF
                        M2=0;
Delay_ms(1500);
                        cmd_lcd(0xc0);
                        str_lcd("DOOR CLOSE");
                                M1=1;
                        M2=0;
                        Delay_ms(30);
                        cmd_lcd(0xc0);
                        str_lcd("             ");
                        M1=0;                                   //MOTOR OFF
                        M2=0;
                        k=0;
                else
                                                        strcpy(temp,pwd);
                                                        cmd_lcd(0x01);
                                                        str_lcd("Confirm Password");
                                                        cmd_lcd(0xc0);
                                                        password();
                                                        if(!strcmp(temp,pwd))
        strcpy(str1,temp);
        cmd_lcd(0x01);
        str_lcd("Password'Changed");
        Delay_ms(1000);
        cmd_lcd(0x01);
        str_lcd("Enter Password");
        cmd_lcd(0xc0);
        pwdchange=1;
        return;
                                                        else
        cmd_lcd(0x01);
        str_lcd("Password Error");
        Delay_ms(1000);
cmd_lcd(0x01);
        cmd_lcd(0xc0);
        pwdchange=1;
        return;
                                                else
                                                         cmd_lcd(0x01);
                                                        Delay_ms(1000);
                                                        cmd_lcd(0x01);
                                                        cmd_lcd(0xc0);
                                                        pwdchange=1;
                                                        return;
                                        else
                                        {goto label;
                                else
                                goto label;
                else
                label:pwd[i++]=j;
                          data_lcd('*');
        pwd[i]='\0';
