Dear All,
Can you please let me know is USB Host source code available for AT91SAM9263 controller.Also I need to know whether USB host code of KEIL MDK-ARM can be integrated in IAR embedded workbench 6.0 for my development and it should run without any operating system.
So I request you to provide this detail.
Best Regards, Zuhair
First I am glad to be able to inform you that source code is available for USB Host functionality for the AT91SAM9263 controller and that same source code (the afforementioned USB host code) could be compiled by the KEIL MDK-ARM package but I have to add that I think it is unlikely that the same code can be integrated into the IAR embedded workbench because, unfortunately, I am not familiar with the IAR environment because, primarily I do all my ARM development with the Keil environment and I am far more familiar with that so I cannot, with any degree of certainty, tell you about the integration question, and it is fairly likely that the source code for an embedded controller can be integrated into an IDE unless that code is written with the intention of being compiled for use in both an embedded system and an IDE when the two said environments are, typically, fundamentally dirrerent where one (the IDE) is probably running with a full blown operating system (such as Windows) and the other (the embedded device) may be running something a lot smaller (such as an RTOS).
Hello, It's nice to hear that there is a driver for the AT91SAM9263 USH Host. How or where can I get this driver?
Greetings Nils
