HI guys,
My project is about switching on and off of motor by sms control.. I tried to check whether my controller is working fine or not using simple blinking of LED program , its working good, no problem with oscillator and reset switch part... everythng is fine but when i try for serial programming i am not getting the output.. I checked my gsm modem using hyperterminal its working fine.but its not working with 8051.
below is my code
#include <reg51.h> void init (void); void Uart_gsm (void); void delay(unsigned char); void Recievedata(); void gsminit(void); void gsmcmdsend(unsigned char *); unsigned char Rx_data(void); unsigned char message[11]; unsigned char count; unsigned char code password1[10]="device1 on"; // Commands for controlling devices unsigned char code password2[11]="device1 off";
void main() { // port initialization
init(); Uart_gsm(); // serial port initialization gsminit(); Recievedata(); // for recieving the data from modem }
void init(void) { P2 = 0xFF; }
void Uart_gsm(void) { TMOD = 0x20; TH1 = 0xFD; SCON = 0X50; TR1 = 1; }
void serial_put(char c) { do{}while(!TI); TI=0; SBUF=c; }
void sms(void) //sending pump is on { char t5[]={'A','T','+','C','M','G','S','=','"','+','9','1','9','1','7','6','3','6','6','4','9','6','"'} ; char t7[]="PUMP IS ON"; unsigned int i; delay(1000); gsmcmdsend(t5); for(i=0;t7[i];i++)serial_put(t7[i]); do{}while(!TI); TI=0; SBUF=0x1A; delay(20000); }
void Recievedata() { unsigned int count,count1,i; while(1) { while(Rx_data()!='+'); // checking message format while(Rx_data()!='C'); while(Rx_data()!='M'); while(Rx_data()!='T'); while(Rx_data()!=':'); while(Rx_data()!='"'); while(Rx_data()!='\n'); for(count=0;count<11;count++) // storing msg in a buffer { message[count]=Rx_data(); if(message[count]=='\r') break; } message[count]='\0';
for(i=0;i<10;i++) //verifying message { if(message[i]==password1[i]) count++; } if(count==10) { P2 = 0x00; sms(); }
for(i=0;i<11;i++) { if(message[i]==password2[i]) count1++; }
if(count1==11) { P2 = 0xFF; } } }
unsigned char Rx_data(void) // TO RECIEVE SERAIL DATA { RI=0; while(RI==0); return(SBUF); }
void delay(unsigned char x) { unsigned int i,j; for(i=0;i<x;i++) for(j=0;j<2000;j++); }
void gsminit(void) { // AT COMMANDS unsigned char gsm_cmd1[]="AT"; unsigned char gsm_cmd2[]="ATE0"; unsigned char gsm_cmd3[]="AT&W"; unsigned char gsm_cmd4[]="AT+CMGF=1"; unsigned char gsm_cmd5[]="AT+CNMI=2,2,0,0,0"; gsmcmdsend(gsm_cmd1); gsmcmdsend(gsm_cmd2); gsmcmdsend(gsm_cmd3); gsmcmdsend(gsm_cmd4); gsmcmdsend(gsm_cmd5); }
void gsmcmdsend(unsigned char *cmd) { unsigned char i; for(i=0;*cmd!='\0';i++) { SBUF=*cmd; while(TI==0); TI=0; cmd++; } delay(2); SBUF=0x0A; while(TI==0); TI=0; SBUF=0x0D; while(TI==0); TI=0; while(RI==0); RI=0; }
I complied this program using KEIL complier , 0 errors and 0 warnings.
After switching On the supply, port 2 goes high..i dont whats the problem with my circuit.. :sad:
