I might find a big bug of rl-tcpNet
I write a Modbus_tcp Slave project using the tcpNet, i think it is very simply. Just receive a request command of modbus_tcp, and then send a reply command. But the project running 1 or 2 days continuously, the communication is broken, and can't connect the tcp again.
Follow are main parts of my project
modbus_callback(...)
     case TCP_EVT_DATA:
         // read the received command data
         recFlag = 1;
         break;
main(){
    sock = tcp_get_socket(TCP_TYPE_CLIENT,0,60,modbus_callback);
    tcp_listen(sock,502);              //get a client tcp socket
    while(1){
        main_TcpNet();
        if(recFlag==1){               //if received a request command of modbus,
            buf = tcp_get_buf(...)    //then reply a data command
            tcp_send(...)
            recFlag = 0;
Then i used the debug library of the rl_tcpNet (TCPD_ARM_L.lib),and want to find the problem.
Follow are the output of the debug library when the TCP communication break.
MEM: Releasing 72 bytes
MEM: Used 80 bytes in 2 blocks
MEM: Releasing 80 bytes
MEM: Used 0 bytes in 1 blocks
ETH: *** Processing Ethernet frame ***
ETH: Dest.MAC: FF:FF:FF:FF:FF:FF
ETH: Src. MAC: 00:19:B9:88:7F:41
ETH: Frame len: 253 bytes
ETH: Protocol : 0800
MEM: Releasing 268 bytes
MEM: Allocated 1 blocks from IRQ
MEM: Used 4294967120 bytes in 0 blocks
what is the problem? Is there some incorrect using in my project?
Is it a bug of the rl-tcpNet? And it can't running long period of time continuously?
if you want to see the more code or the whole project i can send a e-mail to you.
