Hello. as possible to correct LPC2300.s file, that did my processor go across to necessary address?
Did you by any chance use google translate?
translator I chose.
help me. after a start my lpc2378 passes to the unknown storage area. in investigation a processor works not correctly.
Can in the file of LPC2300.is s needed changes?
I'm sorry, but I do not understand what you are asking/saying.
Have you specified correct addresses for RAM and flash in the project, so that the linker will create a correct application for your specific chip?
The startup file should normally not need to be changed just to get the application to run.
It is normally enough to use the configuration wizard (the extra tab you can see if you open the startup file in the IDE) to specify the correct oscillator, and what peripherials that should be powered etc.
Do you happen to have a processor with external memory, so you need to activate the external memory interface?
Unfortunantely, the output from your chosen translator is unintelligible.
It is unlikely that any other automatic translator is going to be any better.
If this is a commercial project, you might be better talking to your local distibutor (whether Keil or NXP), or trying to find a local consultant to help you: http://www.keil.com/condb
If it's a school project, you should talk to your tutor and/or confer with your classmates...
