-LPC2106 -C++ -uVison4 -UART0 -for PC comunication
Hi!
I have problem with UART_write, UART_read func. when want to use cin, cout in my project C++.
I found "How do I retarget C++ streamed I/O?" and retarget.c code (below) but I can't make it to work...
/* * Copyright (C) ARM Limited, 2006. All rights reserved. * * This is a retargeted I/O example which implements the functions required * for communication through an UART. The implementation relies on two UART * functions which the user must provide (UART_write and UART_read) for * sending and receiving single characters to and from the UART. * * See the "rt_sys.h" header file for complete function descriptions. */ #include <rt_sys.h> #ifdef __cplusplus extern "C" { #endif #define DEFAULT_HANDLE 0x100; /* * UART prototype functions */ char UART_read(void); void UART_write(char); /* * These names are special strings which will be recognized by * _sys_open and will cause it to return the standard I/O handles, instead * of opening a real file. */ const char __stdin_name[] ="STDIN"; const char __stdout_name[]="STDOUT"; const char __stderr_name[]="STDERR"; /* * Open a file. May return -1 if the file failed to open. We do not require * this function to do anything. Simply return a dummy handle. */ FILEHANDLE _sys_open(const char * name, int openmode) { return DEFAULT_HANDLE; } /* * Close a file. Should return 0 on success or a negative value on error. * Not required in this implementation. Always return success. */ int _sys_close(FILEHANDLE fh) { return 0; //return success } /* * Write to a file. Returns 0 on success, negative on error, and the number * of characters _not_ written on partial success. This implementation sends * a buffer of size 'len' to the UART. */ int _sys_write(FILEHANDLE fh, const unsigned char * buf, unsigned len, int mode) { int i; for(i=0;i<len;i++) { UART_write(buf[i]); // Fix for HyperTerminal if(buf[i]=='\n') UART_write('\r'); } return 0; } /* * Read from a file. Can return: * - zero if the read was completely successful * - the number of bytes _not_ read, if the read was partially successful * - the number of bytes not read, plus the top bit set (0x80000000), if * the read was partially successful due to end of file * - -1 if some error other than EOF occurred * This function receives a character from the UART, processes the character * if required (backspace) and then echo the character to the Terminal * Emulator, printing the correct sequence after successive keystrokes. */ int _sys_read(FILEHANDLE fh, unsigned char * buf, unsigned len, int mode) { int pos=0; do { buf[pos]=UART_read(); // Advance position in buffer pos++; // Handle backspace if(buf[pos-1] == '\b') { // More than 1 char in buffer if(pos>1) { // Delete character on terminal UART_write('\b'); UART_write(' '); UART_write('\b'); // Update position in buffer pos-=2; } else if (pos>0) pos--; // Backspace pressed, empty buffer } else UART_write(buf[pos-1]); // Echo normal char to terminal }while(buf[pos-1] != '\r'); buf[pos]= '\0'; // Ensure Null termination return 0; } /* * Writes a character to the output channel. This function is used * for last-resort error message output. */ void _ttywrch(int ch) { // Convert correctly for endianness change char ench=ch; UART_write(ench); } /* * Return non-zero if the argument file is connected to a terminal. */ int _sys_istty(FILEHANDLE fh) { return 1; // no interactive device present } /* * Move the file position to a given offset from the file start. * Returns >=0 on success, <0 on failure. Seeking is not supported for the * UART. */ int _sys_seek(FILEHANDLE fh, long pos) { return -1; // error } /* * Flush any OS buffers associated with fh, ensuring that the file * is up to date on disk. Result is >=0 if OK, negative for an * error. */ int _sys_ensure(FILEHANDLE fh) { return 0; // success } /* * Return the current length of a file, or <0 if an error occurred. * _sys_flen is allowed to reposition the file pointer (so Unix can * implement it with a single lseek, for example), since it is only * called when processing SEEK_END relative fseeks, and therefore a * call to _sys_flen is always followed by a call to _sys_seek. */ long _sys_flen(FILEHANDLE fh) { return 0; } /* * Return the name for temporary file number sig in the buffer * name. Returns 0 on failure. maxlen is the maximum name length * allowed. */ int _sys_tmpnam(char * name, int sig, unsigned maxlen) { return 0; // fail, not supported } /* * Terminate the program, passing a return code back to the user. * This function may not return. */ void _sys_exit(int returncode) { while(1) {}; } #ifdef __cplusplus } #endif
