how to define external a const array ?
Hi All,
I have an array struct's with const data in flash memory defined as follows
   const SOD_ObjectDictionaryEntry* pSDOEntryTable = SDOEntryTable;
This works fine ...
I want to use this array in an external file as follows
   extern const SOD_ObjectDictionaryEntry SDOEntryTable[];
Compiling give me following error : error: #513: a value of type "const SOD_ObjectDictionaryEntry *" cannot be assigned to an entity of type "SOD_ObjectDictionaryEntry *".
when I replace it by
   extern const SOD_ObjectDictionaryEntry* SDOEntryTable;
I have the same error.
extern SOD_ObjectDictionaryEntry SDOEntryTable[]
the linker gives an error SDOEntryTable not found , witch is normal.
How can I define a pointer to const data external ?
