I was going through the sample code i obtained from the keil website for LpC2148 USB .As far as i could make out, the code just echos the contents of a buffer onto the hyperterminal when a keypress is detected.
In the PopfromCIrBuf function, i have encountered a small problem. As i understand it, Bufsize is the amt of data to be read in the cir buf and size = size of location we are writing to. Logically , we should write when bufsize<= size but the code seems to be doing the opposite. However this code runs correctly. upon modifying bufsize>= size to bufsize <= size and executing, it did not work. i would like to understand this anomaly. Thank you for your attention. the code is as follows .
#include <LPC214x.H> /* LPC21xx definitions */ #include "type.h" #include "vcom.h" #include "usbapi.h" #define USB_TEXT "\n\r Testing USB NGX's BlueBoard \n\r BlueBoard Revision : 1 \n\r Firmware Version: 1 \n\r For more information on BlueBoard visit ">www.ngxtechnologies.com" /** ******************************************************************* Funtion Name : test_usb() Description : Input : Output : None Note : ***************************************************************** */ void test_usb(void) { U8 buffer[] = USB_TEXT; while((VCOM_write(sizeof(buffer), buffer)) != sizeof(buffer)); } int main (void) { U8 ch = 0; SCS = 3; //sets port 1 and 0 to fast mode (not compatable with previous LPCs) VCOM_init(); while (1) { if(get_USB_enumeration_status()) { if(VCOM_read(sizeof(ch),&ch)) { test_usb(); } } } }
VCOM read is
S32 VCOM_read(U16 len,U8 *buf) { S32 retval=0; if(get_USB_enumeration_status()) { retval = popFromCirBuf(&in_circular_buf, buf, len); if( (retval >0) && (retval < len)) { popFromCirBuf(&in_circular_buf, buf, retval); } } return retval; }
and circlar buffer relevant code is
S32 getCirBufSize(CIR_BUFFER *circular_buf) { U32 retval= 0 ; if ( circular_buf != NULL ) { if ( (circular_buf->readPos <= circular_buf->writePos ) && circular_buf->overflow == 0) { retval = ( circular_buf->writePos ) - circular_buf->readPos; } else if ( ( circular_buf->writePos == circular_buf->readPos ) && circular_buf->overflow == 1 ) { retval = circular_buf->size ; } else { retval = (circular_buf->size - circular_buf->readPos) + circular_buf->writePos ; } } return retval; } S32 popFromCirBuf(CIR_BUFFER *circular_buf, U8 *buffer, U32 size) { S32 retval= 0; U32 i; U32 BufSize; if ( circular_buf != NULL ) { BufSize = getCirBufSize (circular_buf); if ( BufSize >= size ) { for(i=0;i<size;i++) { buffer[i] = circular_buf->Buffer [ circular_buf->readPos ]; if ( circular_buf->readPos+1 == circular_buf->size ) { circular_buf->readPos = 0; circular_buf->overflow = 0 ; } else { circular_buf->readPos ++ ; } } retval = size ; } else if(BufSize < size ) { retval = BufSize; } } else { retval = -1; } return retval; }
It seems logical to extract data from the circular buffer only if it contains at least the amount of data you request, not?
No - it is the number of bytes stored in the buffer at the time of the call. Your statement refers to the parameter provided to the function that read data from the ring buffer.
