using "run user program before"
I would like to use "run user program before" or some such to set a #define from one place in several builds
i.e. build #1 will pick the #define from 'x' build #2 will also pick the #define from 'x'
an example: ONE place to define whether want "debug' or "production" mode which will affect both the build of boot and app.
I do not know if I make myself crystal clear, but if not, do ask.
currently this is accomplished with sepaarte defines and too many mistakes happen.
BTW it would be absolutotally wondeful if the above also could affect a .bat file run in "run user program after"
