Hi, MCU: LPC2138 I am writing a code that takes data from serial port (interrupt driven) and stores it in queues. Here's an overview:
////////////// struct queue{ char *buffer; int wp; in rp; }; char buffer1[6000]; char buffer2[1000]; char buffer3[600]; char uartBuffer[100]; struct queue myQueue; void initQueue(char* bufferQueue, int size) { myQueue.buffer = bufferQueue; myQueue.wp = 0; myQueue.rp = 0; } void enqueue(char *data) { q = &myQueues; while(data[i] != '\0') { q->buffer[q->writePointer++] = data[i++]; if (q->writePointer >= q->size) q->writePointer = 0; } q->buffer[q->writePointer++] = 0; if (q->writePointer >= q->size) q->writePointer = 0; } int main () { char str[50]; UART0_init(9600); UART0_interrupt_init(); initQueue(buffer3, 600); while(1) { sprintf(str, "wp: %d rp: %d", myQueues.wp, myQueues.rp); UART0_sendstring(str); } } void UART0Isr() { UARTbuffer[i] = UART0_getbyte(); // get data until sequence completed if(/*sequence complete condition*/) enqueue(UARTbuffer); }
Now, the problem is that the controller hangs after "enqueuing" 8 sequences(all sequences are same). and the number 8 decreases if i increase the size of sequence.
if i reduce the buffer3 size to 500 or less, code works perfectly fine. for buffer3 size >= 500 ----> code hangs
if i interchange the declaration sequence of global variables like:
char buffer3[600]; char buffer1[6000]; char buffer2[1000];
it gets ok. Atleast for 1000 sequences.
if i disable all interrupts and use enqueue in main in a while loop, its runs fine.
void main() { while(1) { enqueue(sequence); //works fine here } }
Thanks for reading and advance thanks for helpful replies.
Regards, Salman.
It hurts to see your code.
Lots of use of variables we can't see the data type of. Are they global?
Your serial ISR is using an array to store the temporary byte received before enqueue - why?
enqueue() takes a pointer to a char as parameter. How would it know how many characters there are in the array? Does your UART ISR even pick up multiple characters - you using receive FIFO?
Where do you reset your variable "i"?
Why does your enqueue also insert a zero? You don't expect to be able to print the queue buffer directly as a C string? Remember that it's a ring buffer...
How can you have a queue with a write pointer named "wp" but code that plays with a write pointer named "writePointer"?
For some reason, I can not for the life of me understand the meaning of posting random typed text and ask for help. What was wrong with posting the real code? That the real code could possibly make sense? What you typed is just nonsense since it does not compute. It does not compile. That makes it basically just a sequence of more or less random characters that we can't relate to.
Well,
Lots of use of variables we can't see the data type of. Are they global? Ans: Most of the variables are global. yes
Your serial ISR is using an array to store the temporary byte received before enqueue - why? Ans: Because the idea is to store the sequence when it gets completed successfully. Not if it gets corrupted (here corruption implies from external source).
enqueue() takes a pointer to a char as parameter. How would it know how many characters there are in the array? Does your UART ISR even pick up multiple characters - you using receive FIFO? Ans: It would not know. but we will since it will be null terminated.
Why does your enqueue also insert a zero? You don't expect to be able to print the queue buffer directly as a C string? Remember that it's a ring buffer... Ans: No. Idea here is to store multiple strings in a single linear buffer with 0 as delimiter.
How can you have a queue with a write pointer named "wp" but code that plays with a write pointer named "writePointer"? Ans: ok that's my mistake ...replace writePointer and readPointer with wp and rp.
I just cutoff all the unrelated portion of code in order to highlight the main problem. Thanks.
I did the following steps to remap the interrupt vectors in to ram:
> put 0x02 in MEMMAP and copy the exception vectors to ram. (Options for Target > Asm > Define [RAM_INTVEC REMAP RAM_MODE])
> Here's my relevant startup code:
;*****************this portion i copied from other example startup.s file to mine ; Copy Exception Vectors to Internal RAM --------------------------------------- RAM_BASE EQU 0x40000000 IF :DEF:RAM_INTVEC ADR R8, Vectors ; Source LDR R9, =RAM_BASE ; Destination LDMIA R8!, {R0-R7} ; Load Vectors STMIA R9!, {R0-R7} ; Store Vectors LDMIA R8!, {R0-R7} ; Load Handler Addresses STMIA R9!, {R0-R7} ; Store Handler Addresses ENDIF ;*****************this portion was already in the startup.s file ; Memory Mapping (when Interrupt Vectors are in RAM) MEMMAP EQU 0xE01FC040 ; Memory Mapping Control IF :DEF:REMAP LDR R0, =MEMMAP IF :DEF:EXTMEM_MODE MOV R1, #3 ELIF :DEF:RAM_MODE MOV R1, #2 ELSE MOV R1, #1 ENDIF STR R1, [R0] ENDIF
But my issue remains the same. Problem still lingers. Please see if i have missed any step.
I have even done this manually:
unsigned char vectors[64] __attribute__((at(0x40000000)));// reserve space for IRQ vectors void copy_vectors (void) { memcpy (vectors, 0, 64); // copy original IRQ vectors to RAM MEMMAP = 2; // fetch vectors from RAM } int main() { copy_vectors(); //other code }
But this too does not solve the problem.
Now one strange thing is that if remove the bootloader and set the Application code to start in rom from 0x000 and ram from 0x40000000 ..........the problem disappears.
Maybe see this: (Not for LPC21xx, but for LPC23xx)
http://www.keil.com/forum/13106/ Moshe Tal, 10-Sep-2008 17:18 GMT -------------------------------- Additionally, you have to change memory area for application in Options for Target -> Target -> Read\Write memory area to start from 0x40000100 and contain only 0x7F00 (possible lower, but this for safty). So, the application will leave the vectors table RAM untouchable.
http://www.keil.com/forum/13707/ Predrag Despotovic, 13-Dec-2008 12:07 GMT ----------------------------------------- IRAM1 start:0x40001000 size:0x7000 (I was playing with bootloader IRAM1_size. And in my case, bootloader needs somewhere around 0xDFF of RAM. So in order not to overlap it's area, my IRAM1 starts at 0x40001000. Moshe Tal suggested 0x40000100 for his lpc2368 - not enough in my case. Try playing with IRAM1_size in bootloader project to determine your minimum...)
Well, Previously i was using IROM:0x1000 SIZE:0x80000 and IRAM1:0x40000040 SIZE:0x8000 and these are the settings recommended in the NXP's Application Note AN10853 (LPC2000 secondary bootloader for code update using IAP) page 11.
Now as recommended by you i changed it to IRAM1:0x40001000 SIZE:0x7000, and the code is working fine. Thanks for help.
Note that NXP recommendations can't take into account any Keil startup files that performs a memory copy of a vector table into RAM and how that copying could result in an overwrite of other information in case the application have stored something important to the overwritten address range.
It's always important to understand what is happening in a system, which was the reason I did recommend you to first spend time with the processor user manual (to understand the functionality of the processor and the needs) before looking at the Keil startup file.
Hi, In this post:http://www.keil.com/forum/13707/ Predrag Despotovic said that : "(I was playing with bootloader IRAM1_size. And in my case, bootloader needs somewhere around 0xDFF of RAM. So in order not to overlap it's area, my IRAM1 starts at 0x40001000. Moshe Tal suggested 0x40000100 for his lpc2368 - not enough in my case. Try playing with IRAM1_size in bootloader project to determine your minimum...)"
Now my question is why is it necessary to not to overlap the RAM area of bootloader in application code. ? Don't we only need to protect the 64 bytes of exception vectors of RAM area. Wouldn't rest of the ram be available to be used by application code.
It is not necessary. I suppose that in your usage of "protect" you actually mean "not set to 0" upon application startup code execution.
I miss read your previous post. The bootloader and application can share RAM - because the bootloader should never run after the startup process. Note that you could have intermittent software layer between the application and bootloader that _can_ run alongside the application and do require RAM - be careful there.
Yeah i mean to protect by setting application code IRAM1 start address at 0x40 or ox50 for safety lets say. Just enough not to overlap the first 64 bytes of ram.
Other then that changing the iram1 to 0x100 or 0x1000 does not makes sense.
The bootloader and application can share RAM Ok.
But that would be very clear and visible if there is any such software layer. Lets say i am using the default SD/MMC bootloader provided by nxp for LPC2100 series.
In that case what i apprehended is right?
Hi Salman Liaquat,
UM10211 Chapter 29: LPC23XX Flash memory programming firmware
3.2.8 RAM used by ISP command handler ISP commands use on-chip RAM from 0x4000 0120 to 0x4000 01FF. The user could use this area, but the contents may be lost upon reset. Flash programming commands use the top 32 bytes of on-chip RAM. The stack is located at RAM top - 32. The maximum stack usage is 256 bytes and it grows downwards.
UM10114 Chapter 21: LPC21xx/22xx Flash memory controller
5.11 RAM used by ISP command handler ISP commands use on-chip RAM from 0x4000 0120 to 0x4000 01FF. The user could use this area, but the contents may be lost upon reset. Flash programming commands use the top 32 bytes of on-chip RAM. The stack is located at RAM top - 32. The maximum stack usage is 256 bytes and it grows downwards.
In my case, 0x40000200 is good enough.
John Linq, 8-Apr-2009 10:27 GMT
2. Set IRAM1 Start: 0x40000200 Size: 0x7E00
I have no longer worked on the ARM platform for quite a long time. I can not remember correctly that why I reserve 200 bytes. But I do remember that I had found some reasons/explanations before, just fail to recall them. I believe the reason is related to 1st and 2nd bootloaders, ISP/IAP needs.
GNU tool-chain linker script
ieee.ucsd.edu/.../LPC2148-ROM.ld
/* RAM used by boot loader: 0x40000120 - 0x400001FF (223 bytes) for ISP variables */ /* 0x40007FE0 - 0x4000FFFF (32 bytes) for ISP and IAP variables */ /* 0x40007EE0 - 0x40007FE0 (256 bytes) stack for ISP and IAP */
mbed.org/.../LPC1768.ld
MEMORY { rom (rx) : ORIGIN = 0x00000000, LENGTH = 512K ram (rwx) : ORIGIN = 0x100000C8, LENGTH = 0x7F38 ram1(rwx) : ORIGIN = 0x2007C000, LENGTH = 16K ram2(rwx) : ORIGIN = 0x20080000, LENGTH = 16K }
Nice links
Thankyou
