how to handle 2 sms received at a time in gsm module
I am using 89s52 microcontroller to interfacing with GSM module 'SIMCOM300'.
The logic which i develope is as bellow:
1) 1st i execute all commands i.e AT, AT+CMGF=1, AT+CSMS=0, AT+CPMS="SM", AT+CNMI
2) AFTER this controller will do its other operation
3) when new msg received sci receive interrupt will store '+CMTI: "SM", <index> response from gsm in buffer.
4] after this i take the index from buffer & read the corresponding msg content.
5) again the receive interrupt will occure & the whole data rcv from gsm is store in another buffer.
6) so with this i am getting the senders mobile n0.,time of sending, & actual data.
7) Depending on the actual data microcontroller will perform the action.
actual problem:
1) i am use '+' sign to check new msg indication, if '+' sign occur then next data will automatically save in buffer. but while doing this if another sms received then gsm module gives response of that message.
i want this new response to store in buffer but the previous message response already fulfil the condition
so give me the solution to handle two sms received at a time by gsm module.....
