BOLD
for beginners 89c51 is not advisable. better to use very easy 89v51xx chips which have ISP through UART means you need only a max232 ic between the microcontroller and the computer. for more about this here is the schematic and software used check this out
electronics-madeeasy.blogspot.com/.../89v51xx-programmer-using-serial.html
