isr_evt_set problem
Hi, All!
My problem is exactly the same as http://www.keil.com/forum/13634/
void UARTHandler (void) __irq {
   isr_evt_set(0x0001,UART_TASK);
  //use "os_evt_set" works
void task_UART_received (void) __task  {
   for(;;) {
      //can not get here if I use "isr_evt_set":
      os_evt_wait_or(0x0001,0xffff);
I could not reach os_evt_wait_or section, program is always pending in irq interrupt.
But if I change isr_evt_set to os_evt_set everything work fine.
Task task_UART_received is created before first UART interrupt occurs.
I don't understand where error is.
Do you have some ideas about? Thank you.
  • Don't you think you should service the UART before returning from the ISR? Wouldn't you think the UART will request a new interrupt if you don't service it?
    You normally have the ISR pick up any received characters (or send out any outgoing characters). Then you have a thread process the received and queued data, or compute more data to queue for transmission when the UART becomes ready again.
